FJ Cash
Started by Cash Dereszynski, February 10, 2015, 11:26:42 PM
red air scoops
yes
7 (58.3%)
no
3 (25%)
hell no
2 (16.7%)
nice accent
0 (0%)
Total Members Voted: 12
Looks like you enlarged the Speed Triple's angry forehead.
Quote from: Cash Dereszynski on February 19, 2015, 07:39:10 PM
I'd like some opinions on weather I should use the lower cowling? If I do I would make up a CF version. Anybody interested in getting one too?
Cash
A lower that is not affected by DOT3/4 or heat? You might some takers...
Cash Dereszynski
Quote from: giantkiller on February 19, 2015, 07:41:36 PM
More Mock ups to show blast shield in progress.
Fuck it,let's ride.
Cash Dereszynski
Quote from: Mark Olson on February 18, 2015, 03:02:27 AM
Looking good so far..
On the rear wheel , if that is the 92 fj  16" stock wheel then you have the wrong spacer on the brake side.
got the right spacer all good now thanx
Cash
Fuck it,let's ride.
Cash Dereszynski
Waiting for brake switches, petcock parts, rear caliper.
Start mounting CF parts tomorrow ,rework license bracket.
Notice installed front LED blinkers, radial pumps, also installed correct spacer rear axle.
Fuck it,let's ride.
Dhauk
Hi
What make and size rubber are you running on the back wheel , looks thicker than stock .
Dave
krusty
Took my freshly Historic registered FJ1100 for it first run (20klm) today after a 15 year layup. I was pleasantly surprised as the engine felt fresh and strong. Gearbox shifted flawlessly. The only minus is a slight tendency to be slow to return to idle or revs to drop between down changes sometimes. Could be a blocked low speed jet in one of the carbs, no biggie. Everything is working as it should.
ftp://
84 FJ1100 x 2
85 FJ1100
89 GL1500
76 CB750F1
72 CB350F
63 C92 x 2
59 C76
62 C100
63 C100
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E x 2
79 DT250F
Cash
If you were able to do a lower cowling and the front fender, both the forward and aft sections out of Carbon Fiber, I am sure you would be able to move a few.
Possibly contact Randy at RPM and be the Carbon Fiber front fender and lower cowling supplier.
Cash Dereszynski
Quote from: Dhauk on March 05, 2015, 12:45:12 AM
Hi
Dave
Bridgestone Excedra ? 170x70x16
Fuck it,let's ride.
Quote from: Cash Dereszynski on March 07, 2015, 11:54:23 AM
Hi
Dave
On the stock 3.5" wheel?  You enjoy living dangerously, huh?
That tire will be badly pinched with the profile nothing like the designer/engineers intended.  And, its not even a 'sticky' tire but one intended to give long milage.
At least it will wear out faster (if you do long highway miles) in the skinny center bit.
Cash Dereszynski
Quote from: Arnie on March 07, 2015, 07:17:29 PM
Hi
Dave
And your experience with a 170 on that rim? Does the mods I'm doing look like touring mods? Current rim guards are subject to change.
There will be a test stage, and the set up will continue. Thats the fun.
Cash
Fuck it,let's ride.
Cash Dereszynski
Got my CF stuff, installed panels, clear coating cowling/dash. Revised lincense bracket. Cowling brackets tomorrow. And, as always, waiting for parts .
Cash
Fuck it,let's ride.
Cash Dereszynski
Hey,
Assemblied lights,horn, and action cam mount. retorqued front end, Removed baffles final assembly of mufflers, more clear coat on cowling.
More parts tommorow.Hopefully the petcock and and a rolling smokeing burnout.
Cash
Fuck it,let's ride.
Cash Dereszynski
Update:New mock up
Petcock rebuild successful,no leaks,engine starts with a little choke, idles. Temp aluminum cowl brackets, braze actual brass tubes next. Move horn to inside the cowling.
More clear coat,more sanding. Waiting for parts.
Cash
Fuck it,let's ride.
