ZX-R Rear Wheel Mod
Started by Travis398, January 28, 2011, 10:33:53 PM
Travis398
plenty of room near the swing arm.
turbocamino
  Sorry, brain cramp.....at our homepage go to>Troubleshooting/FAQ...then to>Modifications for your FJ ....scroll down to> Rear susp. click on GSXR1100..(which takes you to linked site) half way down page is the ZX7 info....not much there but he did say he machined  sprocket carrier?.... what tire size are going with?
89 FJ1200 saphire.blu owned 8-9 years.  By far the most satisfying of them all. Constant tinkering got me the best bike you could ever want.
Travis398
Quote from: turbocamino on February 19, 2011, 05:03:21 PM
the tire that came with the rim has very little wear on it, so I think I will use that for a while.
craigo
Hey Travis,
Did you have to shim the wheel on the swingarm with any spacers?  I was looking at your pics and couldn't tell.
CraigO
90FJ1200
CraigO
90FJ1200
Travis398
No spacers needed on the left, Except for the bushing that sits in the seal.  Just moved it against the swing arm and everything looked good.
The studs for the sprocket nuts cleared the swing arm by about 2mm. That was a little closer than I liked. so I did grind off 1 or 2mm from the studs.
so I have 3 or 4mm clearance just for peace of mind.
It looked like the studs were a lot longer than they needed to be anyhow.
The right side is the one I need a spacer for.  Probably if I had the stock spacer I could just shorten it to fit. But not sure.
There must be a bushing that fits into the brake caliper bracket that I don't have either.
So I am going to get some measurements and have a wheel spacer made that will taper down for the brake bracket.
I would rather have just a one piece spacer as opposed to 6 big washers, making changing the wheel a pain the butt.
craigo
Quote from: Travis398 on February 21, 2011, 05:55:55 PM
A +1 and a Amen on that one Travis.  The less complicated, the better.
CraigO
90FJ1200
CraigO
90FJ1200
Yea, why have 6 when you can have 1....Isn't that why JB Weld was created?
Quote from: craigo on February 21, 2011, 06:43:36 PM
CraigO
90FJ1200
Travis398
Quote from: Pat Conlon on February 21, 2011, 08:16:46 PM
No that's why the wife was created, Or so she says
turbocamino
Travis.    If it helps any, there are several zx7 axles that include the spacers/bushings on e-bay... i saw a couple for under 30.00.  And yes,there is an axle bushing for the caliper mount bracket.   I was wondering what you where doing for the brake stay/torque arm? .....and if the FJ axle fit ok.  thanks  Brian.T.
Travis398
Quote from: turbocamino on February 22, 2011, 03:35:59 PM
Yeah I looked on ebay, Like you said, if I am going to pay $30+ for a couple spacers that will need to be customized anyways, why don't I just go to the local machine shop and have the perfect spacer made for me?
The axle fit perfectly, didn't change the swing arm so the overall width is the same.
I looked at the back side of the foot peg bracket and it looks like there is quite a few threads in the frame on the other side.
I'm tempted to just put a bolt in there.
quick and easy.
weymouth399
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
dixiethedog
Ive fitted a kawasaki 5.50 wide wheel to my fj1200,remembering exactly what i did is a bit hazy at the moment,but,im about to start getting the bike ready for the road very soon,and will post a bit more info when i take a better look at the bike. From memory,i think ive used an fzr1000 brake and carrier,which i machined to fit,ive used the standard fj12 wheel spindle,with machined spacers and a machined kawasaki sprocket carrier. Pics and more info soon.
Travis398
Quote from: dixiethedog on February 25, 2011, 06:08:41 AM
What year and bike did it come from?
Travis398
Here is the spacer, I decided to remove the seal bushing and have the spacer made to fit into the seal.
this should make lining everything up a lot easier when installing the wheel.
turbocamino
Travis,checking to see if any updates from your project.....i just received all my zx7 parts and have been sizing things up today...I had "sprocket specialties" make me a 39T ($69) and with the 180/55/17 Michelin Pilot CT ($122) that puts gearing back to stock (within 0.4 ) .....I was lucky to find a 94zx7 wheel, already stripped, for $35!.(most where $100)..the cush rubber was junk,but found a new one on e-bay for $9. All other hardware,..caliper with brake line,caliper bracket, brake stay and sprocket carrier from e-bay about $145.   I was wondering where you put the brake stay arm? ... it looks like a longer bolt in the front foot peg mount lines up..but not too happy that the one end of the bolt,for the brake stay,wont be supported?     I did get all the zx7 spacers too..i also have a stash of other spacers, so..hoping for the best there. Then used some 400 then 1000 grit s/paper on the outside 2" of the wheel and the lip ...then went to Harbor Freight and got some buff pad/wheels for my drill and went to work...came out nice!  Then to Tractor Supply for some "Valspar -Tractor and Implement" paint (like epoy paint) will get some pics when done... cant wait to ride it!!
