GSXR Rear Wheel Mod
Started by Perez, October 15, 2010, 08:05:50 AM
I've got to say Bill I'm fairly certain I just kept the original FJ rear master cylinder and connected the suzuki brake line to that. I'll have to check now. :wacko3:
roverfj1200
Quote from: X-Ray on January 27, 2011, 08:07:03 PM
Thats what I did...
1988 FJ1200
Richard.
billwest
I did the same, Ray, just wondering if Craig tried it with the Suzi one.
My rear brakes are a bit different, being top mounted.  I got the brake gear from a Katana.
Sold it!
craigo
Quote from: billwest on January 28, 2011, 12:06:10 AM
Hey Bill,
Is the wheel from a Katana?  Did you have to spacer it in there as well?   Did you use the FJ's brake arm or the Suzuki's?  How about the brake line, FJ or Katana?   :scratch_one-s_head:
CraigO
90FJ1200
CraigO
90FJ1200
billwest
Craig,
The caliper and torque arm are from a Katana.  Wheel, caliper bracket, spacers from GSXR750/1100.  Brake line is a SS one made for the original Yamaha rear brake, with one end modified to allow for the different angle of the point at which it attaches to the caliper.  I used Suzi spacers either side of the wheel, as well as an extra washer each side.
I cut the Suzi torque arm shorter, drilled it, and attached it to the OEM torque arm point on the swingarm.
At various spot in his thread:
   http://www.fjowners.com/index.php?topic=2762.0
are part numbers I used, and a brief outline.
Bill.
Sold it!
jwh
i am converting mine soon (as soon as it gets a bit warmer outside!) and have the wheels and brakes from both gsxr and katana (gsxf, over here) and the using the katana brakes seems alot easier, have mocked them both up in spare swingarm and with the katana one i can use standard torque arm mount and the s/steel hose that is already one it, so thats the way i am going to do it.
craigo
Quote from: jwh on January 28, 2011, 11:34:34 AM
Right on, all roads lead to Rome, so they say  :i_am_so_happy:
CraigO
90FJ1200
CraigO
90FJ1200
Quote from: craigo on January 27, 2011, 11:10:10 AM
OK, as promised, here is the GSXR wheel mod instruction manual.  Keep in mind that this is using a 1990 GSXR wheel installed on a 1990 FJ1200.  I also have this in PDF format.  Need a copy, PM me and I'll send it off to you
I want to thank everyone that provided information to make this manual possible.  To many to mention, but you know who you are.  :hi:
Thanks,
CraigO
90FJ1200
Just to be clear , isn't the gsxr wheel a 17" x 5" wheel not a 5.5" and can only take a 170?
There's more than one GSXR wheel.
Quote from: Mark Olson on January 28, 2011, 01:25:37 PM
Thanks,
CraigO
90FJ1200
I hate to be the etiquette police, but is it really necessary to re-quote the entire post for a single line response?  Try a simple reply.
Quote from: SlowOldGuy on January 28, 2011, 01:35:25 PM
David, is the fact that you didn't delete the long file yourself Irony or Sarcasm?
Scarcasm, I thought it would be obvious.
Just trying to make an example.
Kind of like trying to get my wife and kids to turn out unnecessary lights around the house.
craigo
To answer the question, I used a 1990 GSXR wheel.  In 1990, the GSXR came with a 5.5" wheel that can hold a 80/55-17 tire.
Hope this helps,
CraigO
90FJ1200
CraigO
90FJ1200
craigo
Quote from: SlowOldGuy on January 28, 2011, 02:19:59 PM
Does it work with them?  Have they started turning off the lights?  :nea:
All in good fun,
CraigO
90FJ1200
CraigO
90FJ1200
Wow, an 80/55x17?  That's pretty skinny!   :rofl: :rofl: :rofl:
Oh, a 180?  Never mind ...
I yield the balance of my time to Klavdy  :bomb:
