FJ1300 with a European Twist
Started by aviationfred, November 25, 2015, 09:14:27 PM
Damn! My ploy did not work. Maybe the clear will work for my '89...
CanDman's '89 Snowy is what gave me the idea to go all white.
Yah Fred white looks awesome.... Craap now I'm going to want to do a 4th fj. In white....
Must resist :wacko1:
Quote from: aviationfred on February 12, 2016, 09:05:53 PM
That only works with a polished nitrous bottle mounted on the back though!   :rofl:
The last piece of bodywork is now being worked. Tomorrow all of the newly painted and striped bodywork should be finished and put on the bike.
This project has now wrapped up. The only thing left is to install the smoked tail light and smoked rear signals. I am still waiting on a bracket.
Here is the European Twist completed.
The OEM bodywork will be going into storage for safe keeping.
copper
Looks good but you need to paint the hugger
To jump back a few weeks when I installed the engine. The braided oil lines for the RPM oil cooler each had a spot where the lines rubbed each other. I solved that problem with some heat shrink, fiberglass electrical tape and the original oil cooler line clamp.
Looks good Fred!  Did you go with a satin white?
Quote from: fj1289 on February 22, 2016, 03:10:30 PM
Yes, I went with Satin White paint. I am having reservations on how long the white will look good.  :scratch_one-s_head:
A couple tricks I've learned from the flat black bike - windex is a very good cleaner, and a little WD40 on a rag makes for a very nice "detail polish" - especially if the paint gets a little "chalky"
Fred. You are evil. Now I'm going to have to battle to keep from getting another one. White looks ffnn fantastic.
We all know that most parts for our FJ's are interchangeable. Some parts are not....and mostly, no matter what you do. They will not swap.
I was relaying to Randy a part of my engine build, I was informed that I had unknowingly made a possible grave mistake during assembly.
While installing the pistons and wrist pins. One of the Wiseco spring clips got away from me and I could not find it. No problem, I thought. I have 8 spares from the old pistons. I used one of the Yamaha spring clips and marched on.
The OEM Yamaha wrist pin clips CAN NOT be used in Wiseco pistons :bomb:
There is a .002" difference. That is an extremely small difference, but enough, that over time can allow the wrist pin slide past the clip and make contact with the cylinder wall.
So now after 500 miles on the engine..... I should be changing out the break-in oil for mineral oil and ride it like I stole it. Now.....I have to tear the engine back down and remove the one Yamaha piston spring clip. By the way, I did find the Wiseco spring clip, after the engine was completely assembled.  :dash2: :mad: :ireful: :dash1: :cray: :shok:
Quote from: aviationfred on February 29, 2016, 08:30:39 AM
ouch!  Thanks for passing on the lesson learned - glad you found out now rather than a few thousand miles down the road with damage!
Randy sent me a few photos of what the possibility could be if I don't go back in and change the clip.
