FJ1300 with a European Twist
Started by aviationfred, November 25, 2015, 09:14:27 PM
The cylinder block and pistons arrived today.  :yahoo: They are absolutely beautiful.  :good2:
Very nice Fred!
Jealous of the upgrade.  :good:
Hey Fred what's the cr on those pistons?
Fred, you better check that.... Are you planning headwork?
Randy had to shave the crown to get the Hank Scott 82mm pistons down to 10.5-1 (along with adding volume to the squish area)
Remember: bigger pistons = move volume into the same squish area = higher compression
Good eye Dan!
Quote from: Pat Conlon on December 09, 2015, 01:18:39 AM
Good eye Dan!
At this time, I am not planning on doing any work to the head. It was rebuilt 2 1/2 years ago. I do plan to check clearances very well before the bike gets fired up.
I pulled this from the sale add for the kit. custom WISECO Pro Lite slipper skirt gas ported 1297cc (10.25-1 Compression) Piston Kit
Fred, I also have the Wiseco Pro Lite pistons, curious, what is the measurement of the crown? (from deck to peak)
The valve pockets do look bigger on your pistons than on mine. Probably where the added volume is coming from.
Amazing that these 82mm Pro Lite pistons weigh the same as the 74mm stockers
Hey Fred talked to Andrew's today. Trying to find Turbo pistons for the 1380 block I bought. He said busa pistons are usable.. Otherwise I would have to go through Ross to get custom made dished Turbo pistons.(he said he had to order 30 sets to get those custom made by wisco ) I found busa 83mm Turbo pistons for $429 pins clips and rings included. Have to, some how make sure they will work. But that's probably the way I'll have to go. He said he could machine the pistons down for the 1450 block. So I can get the compression down to pump gas levels.
Hopefully I can get it done by June. Depending on finances.
FJscott
Dan,
Funny you mentioned running Busa Pistons in an FJ.I was just reading an article in the November Cycle World.
There is an article in the service Q&A section where a guy asked if he could use a modern lighter piston from a newer water cooled bike in an older air cooled motor. The experts reply was that it is done frequently with poor results. The Pistons in an aircooled motor have thicker domes and longer skirts to achieve more surface area contact for heat transfer. They will run like a raped ape for a while but prematurely succumb to failure.
I don't know this to be fact, just something to think about.
Scott
Thanks for the heads up Scott. I'll have to check on that. Fred's and Pat's Pro lites. Look like they have almost no skirt.
FJscott
Dan,
Not everything in print is correct, Andrews has built a lot of engines and So I would defer to his recommendation.just felt compelled to pass it on as I just read that article yesterday.
Scott
I started to tear the bike down for the engine removal.
Working on getting decals made.....
