Rotor thickness for 88 FZR1000?
Started by FJmonkey, January 22, 2012, 01:02:53 PM
hey Monkey ,
you can sell the fzr rotors on ebay and recoup the cost. :good2:
craigo
While removing the rotors off my front wheel, I rounded out 2 rotor mounting bolts. Anyone got a spare pair?
I was removing the rotors so I could get the front wheel refinished to match the rear wheel. As in gloss black.
Thanks in advance,
CraigO
CraigO
90FJ1200
grannyknot
Quote from: craigo on January 23, 2012, 07:58:55 AM
Thanks in advance,
CraigO
Craig, I've got a bunch them, shoot me your address and I'll send you a few in the mail.
Chris
84 Yamaha FJ1100L
82 Honda CB450T
70 Suzuki T500
90 BMW K75S
craigo
Quote from: grannyknot on January 23, 2012, 08:38:26 AM
Chris
Thanks a bunch, PM sent to your email.
CraigO
CraigO
90FJ1200
craigo
Hi Mark,
Just want to let you know I did try in earnest to get the rotors measured today but ran into walls in 3 separate shops. I will venture out again tomorrow to get this done for you. I didn't even get my tire off and the rotor bolts removed. But I got a clue on how to do it myself. I just need a small grinder to cut slots into them and use a big flat blade screwdriver.
Will get back to you tomorrow on the rotors.
CraigO
CraigO
90FJ1200
hein
If you grind a slot into the heads of the bolts probably you will destoy the bolts further and or ruin the tip of the screwdriver. You need heat to break the loctite bond. Try using a torx driver that is slightly too big for the existing hole. Heat the bolt head and using an old style impact driver, the kind you hit with a hammer,set it to turn couterclockwise, drive the torx driver into the damaged hole when you've got the bolt hot and it will spin out. I've removed many damaged allen bolts this way.
Hein.
What do you mean, you don't have a lathe?
fj11.5
Quote from: hein on January 23, 2012, 05:35:45 PM
Hein.
last lot of  bolts that wouldnt come out i welded small sockets to the bold head and undone them that way, allen holes were cactus  only needed the discs off the 84 wheel
84 Fj1100  effie , with mods
Here's a page from the '87/88 FZR1000 Yamaha service manual (my son has an '88) :  Also I have a set of front rotors off an '84 FJ1100, which measure 7mm+ if U R interested...
John
'93 Yamaha TDM 850 (x2)
'94 Yamaha WR250
Quote from: Dads_FJ on January 23, 2012, 07:13:31 PM
John
Thanks for the info. 4mm is consistent with the measurements I took. Still does not tell me what the low end is, of course the rotor is over diameter and is now a mute point. I will keep your offer in mind if the other two offers fall through, 7+ is better than my under spec rotors. I am starting to think that all you guys are really "Helpful Honda" sales guys. I have some forks that need polishing....
Sorry, my attention to detail lacks sometimes...  But what I don't understand is, if the starting thickness is 4mm, how can this diagram state the min as 4.5mm?  Shouldn't it be smaller than 4mm?
'94 Yamaha WR250
Quote from: Dads_FJ on January 23, 2012, 09:03:40 PM
My web searches showed the thickness to be 5mm. Really? Half a mm and the rotor is toast? Or worse as you point out the difference between the two pages has the stock rotor starting out 0.5mm under spec.....Too much time spent on rotors I can't use. Thanks for the informative but confusing sharing of the pages from the manual (not your fault, not shooting the messenger). I will let you know if I want them rotors. Thank again.
hein
Relax Monkeyman.
Uncork a zin or uncap a torpedo and revisit Dads FJ's and Arnie's posts.
FZR rotor standerd thickness 4 mm.
89-93 FJ   "              "         5 mm.
Max wear for either .5 mm.
More importantly, did you get the damaged bolts out?
I think I'll let you "polish your fork" by yourself but I'll gladly sell you some Honda parts.
Hein.
craigo
Hey Mark,
My guy says that the rotors are at the max wear limit and in his opinion they are toast.  :dash1:
Anyone want to buy some rapper bling? I'll mount the clock and buy the chain. $5000 obo.  :dance2: :rofl:
CraigO
CraigO
90FJ1200
Quote from: craigo on January 24, 2012, 04:11:58 PM
Hey Mark,
CraigO
Thanks! Option one tossed in the bin, options two and three are stock 86' rotors. Steve (Moparman) have you measured your rotors for any useable life?
And Dads_FJ has rotors at 7+mm offering enough life from now till past the rally.
What do you guys want for a set?
Kinda hoping you wern't going to charge me for taking them.
'94 Yamaha WR250
