Rotor thickness for 88 FZR1000?
Started by FJmonkey, January 22, 2012, 01:02:53 PM
The stock rotor is 7.6mm in the rear .   1mm=.0393"
the fzr rotor is not used because there is a chance of the pads wearing down and the pistons leaking from extending too far out of the caliper causing a rear wheel binding lockup.
IF you have been running this mod for years ,you don't use your rear brake much.
Quote from: Mark Olson on February 03, 2012, 12:59:14 PM
Correct, I'm on the front brakes more than the rear.  However, I'm using the FZR caliper as well... I would think that since they were made to be used together I would avoid having the issue you describe.  Side note: I did just replace the rear pads as I was doing my 'winter maintenance' because they were quite worn.
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
