valve adjust questions
Started by srutherford, April 29, 2011, 12:49:40 PM
gripit_N_ripit
well i took it to the dealer as i don't have  lot of time to do it myself, and i figured why not have it done correctly with no worries, so i took it in. The guy i handed my keys to was perfectly clear UNTIL HE GOT MY KEYS! Then he couldn't answer simple questions that i had so this will be the first and last time i take my bike to them. they wanted $95 for a valve cover gasket..........they must think i'm crazy!!!!
Curtis
Lotsokids
Quote from: gripit_N_ripit on May 12, 2011, 11:41:51 AM
Maybe it's $5 for the gasket and $90 for installation. That gasket SUCKS to install.  :ireful:
..... they wanted $95 for a valve cover gasket..........they must think i'm crazy!!!!
That's not too far off....Yamaha retail price is $91.00   Online is $67.50 at Boats.net and the best is $37 from Randy @ RPM
Quote from: Lotsokids on May 12, 2011, 12:24:59 PM
Not too bad...if you slather it with YamahaBond on both sides like I did...It's getting the bastard off that's the bitch, right Randy?
weymouth399
Quote from: Pat Conlon on May 12, 2011, 12:27:36 PM
Plus 1 most suck to remove :dash1:
A little grease holds it on no problem.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
gripit_N_ripit
Having never performed this job i have no experience to draw from, but i thought it would be recommended or required after removing the valve cover to adjust the valves.? Thats what i recommend anytime i break the seal on any car or truck engine gasket.
Curtis
weymouth399
They can be reused with no problem. They get hard and stiff then leak, then replace or just before.  :lol:
Some use a LITTLE Yamabond on the cam plugs. I haven't in years if it leaks it gets replaced.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
SkyFive
Quote from: weymouth399 on May 12, 2011, 02:04:12 PM
Bob W
Drawing from my automotive background this is good advice. Why use a gasket if your going to slather sealer all over it? It defeats the purpose of using a gasket. I cleaned my used cam cover gasket, got evey speck of silicon that the previous owner put on it, then tacked it lightly in a few places and put the cover back on, no leaks. The key with any gasket is to have a perfectly clean gasket and sealing surface. I learned that the hard way.
gripit_N_ripit
thanks for all the advice. i will humbly return this thread to it's dormant state.
Curtis
Lotsokids
Quote from: weymouth399 on May 12, 2011, 12:56:37 PM
Bob W
My gasket came all distorted and folded (Hungary, remember?). It wasn't even close to the shape of my cover. I used small spots of RTV to hold it, but it didn't work very well at all.
gripit_N_ripit
I have always had good luck with high tack. After you apply it mildly make sure it sets up and gets sticky. however not sure of applying it to a hotter running air cooled engine i think it should still work well.
Curtis
