Colin's FJ1200
Started by FJ1200W, July 18, 2021, 01:08:14 PM
FJ1200W
Quote from: Dads_FJ on August 02, 2021, 11:05:18 AM
This fits the bill and is the one I used on my '89.
Facet - FPF-40178N   12V, 2-3.5PSI
Ordered that pump and the controller Pat recommended.
Thoughts on how to modify the '86 fuel petcock? I don't see any need for the vacuum shutoff, I was leaning toward making it open all the time and installed an inline manual shutoff valve.
Quoteand the search feature -
Hello Tom, a couple of things to do if you want to retrofit a fuel pump on to your early '84-87 FJ.
1) the '84-85 vacuum petcock must be set on (P) Prime (open all the time)  For '86-87 petcocks that don't have this prime feature, you have to convert to a manual petcock or use a '84/85 petcock.
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3AFJPetcock
The closing of the petcock is no longer needed, the fuel pump now controls the fuel flow.
2) The '84-87 gravity feed carbs use larger float needle seats, the '88-95 fuel pump carbs use smaller float needle seats, so you will need to change them: http://www.fjowners.com/index.php?topic=9836.0
If you use the large needle seats with a fuel pump, the higher fuel pressure will push the float needle off the seat and not allow it to fully close and flooding will occur.
3) Add a safety shut off for the fuel pump. On the '88-95 Fuel pump FJ's the fuel pump power circuit runs thru the ignition box so when the ignition box stops sensing a tach signal (engine stopped) the power to the fuel pump stops after a few seconds.
You need to add this Safety feature to your early FJ: http://www.revolutionelectronics.com/Products/Fuel_Pump.html
Everything else is straight forward, pump, wiring, fuel filter, fuel line, etc...
Cheers.  Pat
Thanks Pat!
Columbia, Missouri
USA
Alf
Quote from: FJ1200W on August 04, 2021, 10:52:03 PM
Be careful! 84/85 petcocks don't fit on 86/87 fuel tanks, the screw distance is different. I have to check if 88-93 petcocks fit on 86/87 tanks.
RPM - Robert
Quote from: Alf on August 06, 2021, 01:17:31 PM
Alf you have it backwards. 84-87 all have the same bolt hole spacing and oval o-ring. The 89-95 fuel pump bikes will not fit in the earlier models, the spacing is closer together and the base is smaller.
Thanks Robert. :good:
It has been common to replace the wonky 86/87 (elect.reserve) petcock with the simpler (less expensive) '84/85 petcock.
Troyskie
What Pat said.
I've made that exact swap for my 86.
Alf
Quote from: Pat Conlon on August 06, 2021, 03:08:00 PM
I bought an 86 new petcock last month from an FJ owner that claimed it didnt fit on a 1100, hence my error. Thanks, guys
FJ1200W
Bled the front hydraulics today. Used almost a quart of fluid.
I used an old battery acid bottle and a clear hose, positioned at shown.
Squeeze the bottle before connecting to the bleeder, it wants to suck the fluid out, assisting with the bleeding.
The fuel pump controller arrived, pump should be here soon.
Progress
Columbia, Missouri
USA
FJ1200W
Another sign this bike sat a while. So glad noone tried to add gas and go.
I kinda dig the electronic reserve. But, not the vacuum shutoff  As the new fuel pump has a check valve in in, I'll probably make this one a "full flow" and add a small inline shut off to ease tank removal.
Columbia, Missouri
USA
FJ1200W
I'm thinking about making 10 or 20 of these.
Does anyone think there is any demand for them?
Anti-dive block off plates.
Columbia, Missouri
USA
Quote from: FJ1200W on August 08, 2021, 11:23:40 AMI'm thinking about making 10 or 20 of these.  Does anyone think there is any demand for them?  Anti-dive block off plates.
FJ1200W,
Are all years of anti-dive units the same?  I have a 1985 FJ1100.  I could use two.  What would they cost?
FJ1200W
Quote from: red on August 08, 2021, 01:01:59 PM
FJ1200W,
I'm waiting for my machinist to get back with me, I'll let you know!
84-86 should be the same
I bet these could be 3D printed - hummmmmm
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
Quote from: FJ1200W on August 07, 2021, 06:41:15 PM
Progress
Steve - if you will make sure that bleeder line travels up from the bleeder valve, the column of fluid will act like a one-man bleeder: air bubbles will travel up and out, and bubble free fluid will flow back in
FJ1200W
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
