Colin's FJ1200
Started by FJ1200W, July 18, 2021, 01:08:14 PM
FJ1200W
Busted my FJ out for a bit.
I don't want what I am about to say to sound "wrong" but here I go - re: Colins bike.
Pulled the slave -
I looked up in the pushrod hole for a ball.
There is not one in there, I'm thinking it's only removable from the other side.
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
RPM - Robert
When you have the clutch pack out pull the little pushrod on the clutch cover side of the input shaft. Take a magnet and stick it down the hole. If the ball is there it should come out with the magnet.
Since you have two bikes at your disposal - you have two clutch pushrods.  That should be plenty long to push the ball out from one side to the other....or at least prove to yourself it is or is not there.
FJ1200W
Quote from: fj1289 on September 27, 2021, 09:34:14 PM
Good idea.
Busted my FJ out for a pretty good ride, a little under a couple hundred miles.
No helmet law in Missouri anymore, and this was my first "good" ride without one.
My bike seemed so smooth, stealthier than Colin's. Both run like FJ's, but I'm thinking his is quicker.
'ucking awesome day to be riding. So grateful to be able too.
Columbia, Missouri
USA
FJ1200W
Quote from: RPM - Robert on September 27, 2021, 04:50:26 PM
Will do, plates are due here Friday.
Thanks - and I wore the RPM shirt on todays ride!
No pictures of said shirt though......
Columbia, Missouri
USA
FJ1200W
Columbia, Missouri
USA
RPM - Robert
Holy burnt up clutch steel Batman! Are those bad boys warped?
Pull that down. That appears to some brand of aftermarket, "Kevlar" friction on the front. Followed by a smooth steel floater plate. If they are all kevlar and smooth, then throw all that stuff away.
Make sure you get to that last friction under the snap ring too.
FJ1200W
Quote from: racerrad8 on October 01, 2021, 06:06:32 PM
Thanks for the tips!
Yes, the old one was roached
I went through my stock Yamaha fiber plate stash and found a set that are all 2.97mm or better. Min is 2.8mm I believe.
The Kevlar plates were all in the mid to upper 2.8's.
You have to love these clutches. So quick and easy to work on!
Columbia, Missouri
USA
FJ1200W
Report: Missing handlebar riser cap or plug, I am not sure what the term for it is at the moment.
One was still in place, but loose. A small dab of rtv will fix that.
RPM's superior product comes machined for and with an o-ring to eliminate this problem.
A high performance cover was acquired, installed and it should dramatically reduce track times.
Columbia, Missouri
USA
FJ1200W
Busted out the bikes today, they're both running so well.
I'm ready for Colin to pick his up so I can start on mine.
I was able to squeeze 44 mpg out of my '89, which is better than normal.
Colin's '86, about 34 mpg, but I've been admittedly heavier on the throttle!
Columbia, Missouri
USA
Old Rider
I like the high performance cover ! also good choice with the foamgrips i had a few of them ,but not on the fj dont last too long .They soak water and get wet but give i nice feeling .Soapy water and stubborn force gets them in place  :good:
FJ1200W
Quote from: Old Rider on October 19, 2021, 09:22:31 AM
Thanks - and those grips, they are "NOS" which makes me think they'll not last long, due to sheer age. I've used them for decades, you're right, they have their up's and downs.
One of the best tricks ever learned was using compressed air to remove old grips, works so well.
Colin said he bought a gauge set (his tach has quit working) from someone in the UK. Not sure why he went that far, but some questions I don't ask, I'm just the wrench. As soon as it arrives, I'll throw it in and try to get his bike out so I can start on mine - and then another buddy has a GL650 that needs a quadruple bipass.
I'm hoping to run the bikes side by side next week. If so, I'll post the real world results.
Good times
Even the house repairs..... My father has had multiple floods over the years. He finally bit the bullet and had a demo crew come in and remove the molded drywall, carpet. They cleaned and disinfected. Now we've applied a coat of sealer over it all, Kilz. The water issue should be resolved, and now, well, I'll be a drywaller for a while......
Columbia, Missouri
USA
FJ1200W
FJ's at The Big Bur Oak Tree
Columbia, Missouri
USA
