It's not the float/needle - but gas is still leaking from hose. HELP
Started by aslovik, August 19, 2013, 10:16:38 AM
aslovik
Quote from: racerrad8 on August 29, 2013, 12:43:11 PM
Quote from: aslovik on August 28, 2013, 04:12:26 PM
Randy - How likely is it, do you think, that I tore them when putting in the needle seats not having oiled them? The thing is, when I first ordered two needles from you, I also got (thank you, thank you) 4 complimentary o-rings. I ordered another two needles just to be safe but this time - no o-rings. My question is this: should I pull the needle seats out and replace the o-rings?
Adam
Sorry, I missed this yesterday. It would be wise to pull them and inspect to see if they have any damage or tears, that is what I would do. I though I would be kind and include as you put it a set of "complimentary" needle seat o-rings on the first order.
You then said;
Quote from: aslovik on August 26, 2013, 12:30:45 PM
Then, I replaced the o-rings, and didn't oil them so might have damaged them - because it still spews gas!
So, plan is to re-replace the o-rings, two new needles for the ones that appear fine but what the heck. And pray a lot.
Thanks for all the help and suggestions
Adam
So, then I recommended the S/S carb & o-ring kit as it would supply you with all of the o-rings for the carbs as well as the replacement screws in S/S allen head bolts.
But the order came in for just two more needles...
You've been *more* than helpful and generous. Didn't mean to imply anything else. It is just that if I didn't tear the o-rings putting them in, I didn't want to now tear them taking them out...
Thanks again
Adam
aslovik
IT RUNS! Free at last, free at last; thank god I'm free at last!
Thank you all for all your help, advice, and patience.
(Now I just have to figure out why the rear brake doesn't work at all - maybe need to bleed the brakes?)
Yipeeee!!!!  :dance2:
:good2:
Quote from: aslovik on August 29, 2013, 08:07:17 PM
:good2:
The rear brake is way over rated.... 20% of braking at best... Are you racing???
Quote from: aslovik on August 29, 2013, 08:05:14 PM
Thanks again
Adam
No implication taken by me, I am glad it all worked out.
Did you check them or take the chance?
Flynt
Quote from: FJmonkey on August 29, 2013, 08:12:31 PM
how about just holding the bike at a stop...  fix the brake.
Fourex
Yeah,  A little rear brake will stop Wheelspin out of the corners. . .Cheers Fourex.
