Front brake caliper
Started by wildecoyote, August 09, 2013, 02:31:07 PM
wildecoyote
Does anyone know on my 1989 fj1200 how many pistons inside the caliper are suppose too engage. They are seized inside the caliper, I took a little heat and used my compressor to push them out, but only one popped out.
ALL OF THEM!
If it's seized, order the kit(s) and do it all.  And ffs don't drive the thing if you're shy on braking power, unless you're a proper nutjob.
FJscott
wildecoyote
That's what I thought, but wasn't 100%. Thank you for your knowledge
wildecoyote
Thank you. I appreciate the welcome
FJ111200
Quote from: FJscott on August 09, 2013, 02:40:21 PM
2 per caliper
Quote from: wildecoyote on August 09, 2013, 02:43:14 PM
I thought the '89 was a four pot caliper.
Yep ,89 is a 4 pot per caliper,
WildeCoyote, you need to post up some good pictures of your bike!
I want to see that paint job! Hard to see with the size of your avatar, but it looks really cool! :good:
I think you should be able to unbolt the two halves if your front calipers are stock '89.............might be easier to completely disassemble them for cleaning/rebuilding..........
Or just source a pair of R6/R1 calipers from an '03 or earlier bike on ebay.......they bolt right on, and use the FJ rotors!
For the cost of this set of Blue Dots and a new set of brake pads, you would be way ahead of paying for rebuild kits for the OEM calipeers.
http://www.ebay.com/itm/254-YAMAHA-FZ1-FRONT-CALIPER-1-/221258495308?pt=Motorcycles_Parts_Accessories&hash=item338408b54c&vxp=mtr#ht_3500wt_1161
