Xj750 cdi on Fj1200?
Started by Fj1200buggy, July 25, 2013, 03:39:57 PM
Fj1200buggy
Hi, my fj1200 cdi is broken and someone is offering me a xj750 cdi, Will it work?
Thanks.
fintip
Heh... Not likely, and if so, probably not well--assuming the connector even fits?
That being said, I have seen some crazy CDI swaps work... two cylinder honda dirtbike CDI working fine on a Transalp Vtwin. And the XJ750 was along the same development line and is a Yamaha. I would say it can't hurt to try, but in theory, maybe it could. Probably not much though.
I wouldn't gamble more than $10 on it though; surely it isn't that hard to find a used CDI?
fjowners.wikidot.com
-ZAMM
IBA:54952
As long as you connect the right wires together, it should work.... An ignition does the same thing on any engine.  Timing advance curves may be different, though... If you csan find an XJ service manual, it should list that info.
Fj1200buggy
Its hard to find a used cdi in South-Africa, will the fj1200 cdi be closer to a fjr1300 cdi?
Quote from: Fj1200buggy on July 26, 2013, 02:20:51 AM
I'd try the XJ CDI before I'd try the FJR piece...does the FJR even have a separate CDI?  I'd assume the ignition control is handled by the ECU controlling the fuel injection.
Definaty search the Internet to get an XJ manual to get the wiring specifics and advance curve characteristics. May need to slot the holes in the FJ backing plate for the ignition to adjust timing for any differences.
Good luck and let us know how it goes!
Fj1200buggy
Does anyone have the wiring diagrams, I think its a 1986 without a fuel pump.
Thanks.
JPaganel
Quote from: fj1289 on July 26, 2013, 09:37:27 AM
There are both carbed and FI XJR1200. They switched to FI about I have never seen an XJR in person (in their infinite wisdom Yamaha has never imported them into either North or South America), but from what I'm told, the carbed ones are very similar.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
FJ111200
Quote from: JPaganel on July 26, 2013, 12:04:15 PM
I recognise that name from www.xjbikes.com , The XJR1200 didn't get FI,  but the later XJR1300 did. You're getting the XJR and the FJR mixed up.
Fj1200buggy
So, does anyone have any wiring diagrams?
fintip
I got one I can put up later this evening if I remember--post another reply here to draw my attention to it, haha. It's partially colored (hand colored on a computer, that is).
-ZAMM
IBA:54952
Fj1200buggy
fintip
I painstakingly put this together from hand by screenshots from multiple pages from a pdf that I found on google. Different ones were taken at different zoom rates. It was tricky because I was on an 11" netbook!
Voila!
(copy and paste the following into a new browser window or tab--they are too big to embed here)
http://imageshack.us/photo/my-images/14/8687wiringdiagrambig.png/
http://imageshack.us/a/img24/6427/8687wiringdiagrambigcol.png
http://imageshack.us/a/img35/746/electricalcomponents.png
http://imageshack.us/a/img694/6427/8687wiringdiagrambigcol.png
http://imageshack.us/a/img171/6427/8687wiringdiagrambigcol.png
Also, now posted at fjowners.wikidot.com/electrical, and probably eventually to be added to fjowners.wikidot.com/wiring-diagram and then linked from that page.
-ZAMM
IBA:54952
Fj1200buggy
Thanks allot, I really appreciate it.
Fj1200buggy
What does the flasher unit do?
Fj1200buggy
Can not grounding the coils cause no spark/the cdi to fry?
