Turn signal electrical question
Started by Paul1965, July 05, 2013, 04:22:44 PM
Paul1965
Is there anything special about how the turn signal wiring works on the 84 FJ? I'm trying to install some additional LED marker light/turn signal assemblies and cannot get them to function properly. They have a red (running), green (turn signal) and black (ground) wires. If I connect the running to a key on source and connect the ground, they light up fine. However, as soon as I connect the turn signal, I lose the running light and they will only flash. If I make my connections to a regular 12V source like my trickle charger, the LED lights work as they should. When I check the wiring on the bike, things seem just fine. Thanks in advance for any help!
1978 Yamaha 400 Sold
1984 Yamaha Maxim 400 Blew up
1982 Yamaha Vision Sold
1983 Kawasaki GPz1100 Sold
1984 Yamaha FJ1100 Killed it
1991 Yamaha FJ1200 Sold
2009 Triumph Sprint ST Sold
2014 Triumph Trophy SE
Antonn3
Hi Paul, the  84/85 does not use 3 wires to operate the turn signals, you only use the green and black as  those  supply the 12 volts.
The tail lights use 1157 bulbs which are the running lights ( 2 filament bulbs).
The turn signals use 1156 which are single filament bulbs.
So only use the green and black wires and your good to go.
Good luck,
Tony
Paul1965
Quote from: Antonn3 on July 05, 2013, 05:23:49 PM
Good luck,
Tony
Thanks, I understand that the OE turn signals are only a 2 wire connection. That's why I used a key on power source (from the ignition switch) to power the running light side of the LED's. It's once I connect the turn signal portion to the OE lights that they fail to operate properly.
"They have a red (running), green (turn signal) and black (ground) wires."  Are you absolutely sure black is ground?  When I installed an LED tail light on my FJ there was a black, red, and white wire (and no instructions)... the white wire was common (ground).  Also LED lights have a much higher resistance than incandescent bulbs... turn signal circuits can be dependent on the low resistance of an incandescent bulb to work properly.  Have you tried contacting the manufacturer of the lights?
'93 Yamaha TDM 850 (x2)
'94 Yamaha WR250
Paul1965
Quote from: Dads_FJ on July 05, 2013, 10:20:40 PM
Yes, I am sure black is ground. In my original post I pointed out "If I make my connections to a regular 12V source like my trickle charger, the LED lights work as they should"
Do the lights work properly as JUST turn signals?
You may be able to put a diode inline to keep the circuits separate and have them both work, but I'd want to look at a schematic of the lights you're using before making any real comment or suggestion.
Paul1965
Quote from: Arnie on July 05, 2013, 10:35:09 PM
Yup, they work just fine as either a turn signal or as a running light, just not both when I connect them to the bikes turn signals. If I connect the running light and then use the same 12V source for the turn signal, they operate as they should (go from dim to bright), so I'm fairly sure it's not an issue with the lights. These are the lights, and of course they came with no instructions: http://www.amazon.com/gp/product/B006FSS2KG/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
......Also LED lights have a much higher resistance than incandescent bulbs... turn signal circuits can be dependent on the low resistance of an incandescent bulb to work properly.
John, actually it is the opposite...
That's why LED indicators need a in line resistor for the reed switch to flash properly.
LEDs are very energy efficient and have a low resistance compared to incandescent bulbs.
Cheers.
Quote from: Pat Conlon on July 05, 2013, 11:13:09 PM
Cheers.
It's all good. :)  but I still think I'm right that "LED lights have a much higher resistance than incandescent bulbs".  Matter of fact I'll bet you five bucks...  But we need someone else to prove the point.  :drinks:
'94 Yamaha WR250
oldktmdude
Quote from: Dads_FJ on July 06, 2013, 08:30:26 AM
Cheers.
I'm with Pat on this one!
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Paul1965
Quote from: oldktmdude on July 06, 2013, 08:33:28 AM
Cheers.
Like Dads FJ said, LED's have next to nothing for resistance. That's why a load resistor is needed to prevent the flasher from going crazy and acting like there's a bulb out (flashing fast).
oldktmdude
   LED's require alot less power to operate because there is less resistance than a normal bulb.
2009 TDM 900
2004 GasGas Ec300
You're not arguing with me, you are arguing with ohm's law... if V/R=I (volts divided by resistance = current), then lets plug in some numbers...
12 volts divided by 1 ohm (very low for our example) = 12 amps of current.
vs.
12 volts divided by 12 ohms = 1 amp of current.
Now: Power = Volts * Amps
our first example of a very LOW resistance will be 144 watts of power (12*12)
vs.
our second example of HIGHER resistance which is only 12 watts of power (12*1).
'94 Yamaha WR250
By adding a resistor to an LED turn signal for my rear indicators, it keeps them flashing properly. With out the resistance the flasher unit thinks the bulb is blown and flashes faster to alert me of the problem. I am guessing by this simple example that LEDs have a low enough resistance to register as an open circuit (blown bulb) by the FJ flasher system.
Quote from: FJmonkey on July 06, 2013, 11:56:57 AM
No, not an open circuit, a short.
The resistor limits current, slowing the response of the metal strip in the flasher.. it's the high current in the flasher that builds up heat in the mechanism that causes it to flash rapidly.
At least that's the way I understand it.    :unknown:
