Exhaust systems
Started by Shaun, September 24, 2009, 10:51:13 AM
Shaun
Apparently I am going to be looking for a new exhaust system for my bike. The collector box is forming holes in several place and leaks like a sieve. I like the balance look of a 4 into 2 system but I mainly see 4 into 1 setups. I don't want something overly loud, and I would prefer 4 into 2 but that may have to change. Any suggestions as to a reasonable system out there, or different manufacturers a guy could investigate.
Thanks
Shaun
the fan
there is an ebay seller listing delkavik stainless collectors that are listed as a direct replacement to stock.
Shaun,
I just put a Kerker 4-into-1 system on my 90. I found it from a seller on e-bay that has posted a bunch of Kerker systems that he claims are New Old Stock. It arrived in a Kerker box that looked like it had been sitting around for quite some time, but it was definately in New shape.
I installed it in about 2 hours from start to finish. it fit very well, and is not overly loud. I weighed everything that I removed/installed on the bike too, and I saved a total of 21 lbs from the factory system. I took some video clips of the sound difference also, I can post the youtube links to them if that is allowed. The only thing that didn't seem to fit quite right is the bracket that you mount to the factory exhaust can mount point. it seems just a bit too short, and they have you change the height of the rear brake lever to compensate(so that it doesn't contact the midpipe). I think i am going to make a slightly longer bracket myself, and fix the brake lever back to where it should be, cause I am not used to it being that much higher than the footpeg.
Anyway, mine is a 90, but he had posted different ones for various years of FJ.
Mesa, AZ
Shaun
That would be great, your bike is the same colouring as mine and it looks like you have the 4 into 1 on there. It looks pretty nice. I'll have to check for the kerker system on eBay but so far no luck.
Shaun
Ratchet_72
With the Supertrapp you don't have to remove the manifold to access and drain the oil. I believe with the Kerker you do. A serious consideration.
Jason Cox
2000 Honda CBR1100XX
1977 Ironhead
Sacto, CA.
threejagsteve
Quote from: Ratchet_72 on October 02, 2009, 05:57:57 PM
Supertrapp is no longer available, unless you can get one by special order. I haven't tried to call 'em to see, but that'd be my first choice if I was looking for a pipe. If somebody does call them, please post their reply.
TIA, and Kookaloo!
EricB
I would shy away from V&H
The exhaust flange fit was horrible, you can't drain oil (I knew that when I bought them) and their customer service sucks.
smokamoto
On the 92 I had years ago, I put a Vance & Hines SS2-R on it.  Really nice nickel plated pipe, not too loud, ran great with minimal carb fiddling.  I think it had to come off to access the oil drain plug.  Unfortunately, they are no longer made.  So on the 91 I recently bought, I put a V&H Supersport on it.  Cheap ($328.00), fit ok, had to re-position the rear brake linkage for clearance, it's too loud, the paint started to flake off the headers almost immediatley (and I used latex gloves to put it on), it caused a 1/8 throttle hubbabubba stumble that fuel screw adjustments aren't curing (I did up the main jets).  Still needs some carb fiddling (can't wait to pull those carbs AGAIN).  Oh, and you can't get to the drain plug.  I now remove the left oil cooler line to drain the oil.  Not as thorough as the drain plug, but good enough for me.
smokamoto
'85 RZ500N 6310 kms
'01 FZ-1 11k miles
1990 Yamaha FJ1200 Stock Exhaust
1990 Yamaha FJ1200 exhaust with stock Silencer cans removed
1990 Yamaha FJ1200 exhaust with collector box removed
1990 Yamaha FJ1200 exhaust with Kerker 4-into-1 system
Here's the links to my Exhaust Video clips
My camera doesn't quite record the volume of loud things very well.
With the pipes removed, inside my garage, it was like 10 times louder than the video clip sounds like.
I wasn't sure if my neighbors would come out to investigate, but none did.
The Kerker system isn't too loud. it's not annoying going down the road, but the one drawback I can already look forward to is when it comes time to change the oil again......well......you know the rest. :negative:
thuber3040
The kerker looks nice on there :good2:
1985 FJ1100 Finally Home
1984 FJ1100 New purchase
1978 KZ1327
1973 H2
Shaun
That looks and sounds pretty fine to me, so far though no joy on the market, but the hunt will continue. Thank you for taking the time to post vids and pics though, it is a clean looking system that is for sure. And quite possibly quieter than my existing set up.
Thanks
Shaun
Shaun,
I e-mailed the guy I bought my system off of, to see if he had any more available, but have not heard back from him yet.
I'll let you know if he responds.
:unknown:
One thing to watch for with that Kerker exhaust is when you start to hear a metallic rattling sound in the muffler it's time to re-pack it.
The resonator is only rolled over on the front side of the muffler (pipe) and when the packing material burns away it vibrates.
