Clutch hydrolic cylinder rebuild
Started by kawabob1, March 17, 2013, 09:23:54 PM
kawabob1
Hi all,
Only about a foot of snow left till I can get the '85 back on the road. I am rebuilding the hydraulic master cylinder for the clutch. I ran into a problem trying to get the circlip out that holds in the plunger. My circlip pliers are too short to reach the clip. Is there as special tool? Also, I am changing the chain and sprockets. Any clear choice as to use a riveted master link vs a clip style? Thanks everyone.
Look the grim reaper right in the eye...and say....someday......but not today! Life is short, live it well!
Just get longer ends to reach down in the hole. mine were just long enough. Rivet chain is safer, if you clip on a master link then safety wire it
kawabob1
Rivet was my first choice, I appreciate your input FJmokey...now to find a little longer tool....story of my life!
Quote from: kawabob1 on March 17, 2013, 09:33:56 PM
Yep, I feel for ya.....
I bought a small set of needle nose pliars with a long snout.  I ground the sides of the snout jaws until they fit into the retainer holes.  The jaws were initially not strong enough to compress the retainer until I bent them slightly toward each other.
Works great now.
kawabob1
Thanks David!! That sounds like a yankee idea to me.....I like it!
bigbore2
Those are hard to get out without the right tool. All else fails just take it over to a shop, they might do for free.
