intermittent starter skipping
Started by backstreetheros, January 27, 2013, 03:53:50 PM
backstreetheros
my starter on the turbo chopper skips, randomly, sometimes it doesn't engage at all, sometimes disengages mid crank, sometimes its fine...
is there any common problems for this or should i just get another starter?
doesnt bother me for a minute but will be a bit embarrasing out on the road.
cheers
You can't turn a pig into a racehorse... So lets see how fast we can make this pig go!!
Quote from: backstreetheros on January 27, 2013, 03:53:50 PM
cheers
It is not the starter, but the starter drive. The starter drive is not a serviceable item without the splitting of the cases.
If the oil is old, thinned with fuel or super thick it will have these issues. Change the oil a few times to clean the internal portions of the engine and hopefully the issue will go away.
I not you will have to split the cases and install the later model XJR sprag style starter drive which was designed to eliminate the issue you are having.
