Installed Randy's oil filter mod
Started by craigo, January 06, 2013, 04:52:56 PM
craigo
Easy as pie, just needed a deep reach thin walled 1" socket, a little blue loc-tite and some white grease. Went in so nice and looks great. :yahoo:
Great customer service from Randy. BTW, got here real fast. Thanks Randy
CraigO
CraigO
90FJ1200
Great thanks Craigo, will be getting mine in the next week or so.
I'm doing the oil cooler kit as well, can't wait.!
oldktmdude
Quote from: X-Ray on January 06, 2013, 05:24:54 PM
Ray, you probably already know, but incase you don't Ryco Z411 and Ryco Z148A (or other brand equivalents) are easily obtainable and cheap filters, that suit the spin-on adaptor.   Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
craigo
Quote from: oldktmdude on January 06, 2013, 05:41:02 PM
I used a Bosch 3312, spun right on, it's black and it matched the engine. But I'm sure Randy will suggest the WIX filter. Pricey, but the check valve gives it an interesting aspect.
CraigO
CraigO
90FJ1200
Yup a very nice upgrade. Makes you want to change oil now just because... Looks great also. I run WIX because it's handy and black, but lots of filters will work and a little dab of black bug bomb will do ya :). You wonder why in the heck didn't you do this a long time ago.  :good2:
The spin on oil filter adapter was one of the very first mods that I did after I purchased my bike. For the purpose of availability, (if you need one right now today) I crossed referenced the filter part number and found that the filter is for a 1988 Acura Integra with the 1.8l engine.
craigo
Fred,
That was a 1.6l motor, not the 1.8l, because I just did the research....
Any of these filters will work:
http://www.autozone.com/autozone/parts/1988-Acura-Integra/Oil-Filter/_/N-iho4dZajdeo
CraigO
CraigO
90FJ1200
craigo
Well I went out to the bike this morning to find a puddle of oil under her. It appears to be leaking from the drain bolt. This has never happened before so I have to ask, will replacing the washer between the bolt and oil pan fix this or do I have bigger problems?  :dash2:
Thanks in advance,
CraigO
CraigO
90FJ1200
Quote from: craigo on January 07, 2013, 12:32:13 PM
Thanks in advance,
CraigO
The washer is a crush washer and should be replaced every oil change. I say should be, but I have used the same washer since I got the bike over 15 years ago with no leaks at the washer. You might be able to tighten it just a little bit more. Use a torque wrench to prevent over tightening and stripping out the threads. If that don't work then decide if you can live with the leak till your next oil change. Or drain the oil into a clean container, put a new washer on and put your new oil back in.
craigo
Thanks Mark,
Yep, that's what I was thinking too, that is was just a crush washer issue. But, since I never in all my years came upon this problem, I'd thought I'd ask the experts.  :good:
Thanks again,
CraigO
CraigO
90FJ1200
Thanks Pete, I went and got 2 K&N black filters, model KN-202 from a place in Sydney off ebay. $17.00 ea, bit pricey but they are black and ready to go on so all good. Linky = http://www.ebay.com.au/itm/K-N-OIL-FILTER-HONDA-VFR-VT-KAWASAKI-V750-EN-EX-KN-202-/180626740455?pt=AU_Motorcycle_Parts_Accessories&hash=item2a0e3154e7
I ordered a new drain bolt from Randy with my goodies, I didn't check if it comes with a new crush washer or if these are seperate. I have been reusing the same one over and over with no probs so far.....
markmartin
Thanks in advance,
CraigO
Might it be oil that is dripping from the chin fairing from when you did your recent oil & filter change?  I have found a few drops of oil under my bike after an oil change--- the next day--- from when I pull the filter housing off and consequently spill oil into my chin fairing and all over the header pipes.
Hopefully just a crush washer. I hate to admit it but the first time I put the spin on filter adapter I got that &**%##$ wire caught under the O ring and it leaked.... Stupid me.. Got a new O ring and reinstalled. Now no problem with the wire forever. I really like the conversion and would recommend it as one of the first things to do. I ordered a few extra crush washers to have on hand, now I hope I can find the things when needed..... With a crush washer in hand you might be able to locate one at NAPA or a discount auto store in a pinch.
craigo
It's a fix, just put on a crush washer and she's high and dry. Thanks all for the responses. And I think we all at one time or another pinched that wire under the filter housing. I remove the chin fairing when I change oil so I can clean up in there. It sure gets grimie between the frame rails and the chin fairing.
Thanks again,
CraigO
CraigO
90FJ1200
motohorseman
I broke down and ordered one several weeks back, hope to actually install it in the next couple of days.
Picked up the filters this afternoon, forgot to order them when I bought the adaptor  :shok:
