Low speed ratcheting with throttle on off
Started by WIFJ1287, July 03, 2009, 01:06:49 PM
WIFJ1287
There must be a torque converter on the front sprocket? That wears over time?
I have a little ratcheting going on in the city driving when gassing in 1 and 2 gears.
Seems like a noise coming from up front near drive sprocket..no shifting problems.
Could be sprocket slop? Still running the originals at 25k.
Any suggestions?
Thank you.
the fan
WIFJ1287
 :crazy: Yep I studied the manuals today.
Any tips on the new driveline change..looks like this ones going to be up on the stand
after the weekend.
Thanks
Loosen the countershaft sprocket nut before removing the chain.
Trust me on that.
the fan
Don't cheap out on parts. Replace both sprockets and buy a top line chain. I am partial to the EK SRX chain, but I ride a 600 and change it out at around 6-7000miles. I hear real good things about the EK zzz series and the VM series from DID. I use JT sprockets, but again I do not expect alot of life out of them. Thats not to say JT is a bad product, just that I prefer not to run worn chains and sprockets.
If I were running a stock FJ, I would really consider the OEM countershaft sprocket, top line Riveted chain, and the rear sprocket of your choice.
Good catch.
An FJ can destroy a chain tremendously easily.  Broken chains most of the time are just a hassle, but occasionally will wrap the countershaft and add all sorts of ventilation to parts of the cases.... BTDT..
WIFJ1287
Thanks alot, I have a DID Xring 110 I bought a while back.
I dont see a master link on the stock chain?
Countershaft would be reverse thread?
41 or 40 rear? likes?
Bolt cutters?
Ratchet_72
Jason Cox
2000 Honda CBR1100XX
1977 Ironhead
Sacto, CA.
Yamifj1200
Quote from: WIFJ1287 on July 04, 2009, 02:59:54 PM
Bolt cutters?
The countershaft is not left hand threads. They are metric right hand threads.. you can grind the pins down on any one link and use a chain press to remove any link from the stock chain.
Eric M
WIFJ1287
Got it worked like a charm with 4.5 grinder and a nail set. I just sat on top of the bike and spun the front loose with
a 36mm socket wrench
