Lets try this again
Started by irishluck, September 06, 2011, 08:10:34 PM
In your previous thread you stated that you put LED bulbs in the back housings..... If there are LEDs in the system ANYWHERE it WILL affect flasher operation!  Put standard bulbs front and rear and report back..... otherwise you're just wasting EVERYONES time!   :dash1:
irishluck
ok i understand the euro version. yea the haynes manual does seem messed up. everything on the bike is 87 except the frame.
Quote from: RichBaker on September 07, 2011, 09:04:07 PM
no it doesnt, cause i was running the LED blinkers in the back for weeks and it worked perfectly fine not a problem, idc what anyone says about that, it isnt true cause ive been running them perfectly fine for weeks
the only reason im having a problem now is cause i added new front ones and a new handlebar switch, everything worked fine until then, so then i put the old front ones back on and the old handlebar switch and it still doesnt work, i know its  not the LED turn signals
Even before i put new LED ones in the back the rear ones were LED already when i bought the bike and they worked fine too, only reason i replaced is cause the stems were broke
Flying Scotsman
I put leds on my bike 1985 1100 and they didnt flash had to add the old rear bulbs back into the system to make them work.
1990 FJ1200
1999 GP1200 (165 + hp)
irishluck
ill grab some standard turn signals from work tomorrow and put them on there and i know they work cause ive tried standard ones already
Quote from: irishluck on September 07, 2011, 10:49:16 PM
True dat.
I'm going for the reverse psychology angle:
OK Irish, you are right.  It simply MUST be that flasher, these other guys are idiots. Seriously spend lots of money replacing it.  I think I would buy a dozen different flashers from other bike models, until you find one that works as a replacement for you.
Best of luck to you.
If you are certain that it's the flasher, replace the flasher.  Rocket surgery it ain't.  It's a $8 part or so, and probably worth doing instead of rechecking the wiring (or arguing that it can't possibly be wrong).  I'd suggest getting a solid-state fixed rate flasher rather than the load dependent type (they're commonly available, if you can't find one, look at a place that sells lighting to truckers).
That said, I don't think a relay of any size is going to fix the fundamental problem here--not necessarily the one about the lights.
Quote from: andyb on September 08, 2011, 08:08:34 AM
Maybe it's time to try a solenoid.
Quote from: SlowOldGuy on September 08, 2011, 08:53:11 AM
:rofl2:      (popcorn)
irishluck
if you cant tell me where to find one for $8 i prolly would buy it buy now, but any bike site i see them on there $100+
If i could find one i would of bought it, but i cant find any cheaper than $100
ddlewis
If you are sure it's the relay and not your carbs...
the cheapies at the part stores ($3-$8) are probably like the stock unit and going to work best with incandescent bulbs..
however goolgle "signal flasher relay led motorcycle" turns up several and I can't find one for > $20
ddlewis
Quote from: ddlewis on September 08, 2011, 09:23:44 AM
...however goolgle "signal flasher relay led motorcycle" turns up several and I can't find one for > $20
meaning there are several $20 and under..
irishluck
Quote from: ddlewis on September 08, 2011, 09:25:48 AM
I was talking about the stock flasher for the motorcycle. to replace it cause I think its bad. that one is like $100+ for it.
and even if i got one for the LED turn signals id still have to get the stock one for my bike if its bad.
ddlewis
Quote from: irishluck on September 08, 2011, 09:40:57 AM
Wha?  your stock one is either bad or more likely will not work with low amp LED's. (assuming it's not wired up wrong)
So I'm saying replace the old school stock unit with the newer solid state type for $20..
irishluck
Quote from: ddlewis on September 08, 2011, 10:42:14 AM
ok then let me ask you a question here, how do I go abouts wiring up a newer one to the 10pin or how ever many pins it is old stock flasher. Cause ive looked at newer flasher relays and they only have like 3 wires on them
irishluck
I mean I can grab a rumble concept flasher relay from where i work for $5 brand new
(didnt mean to make a second post on this)
