turns over very slowly when hot
Started by karl61, July 28, 2010, 11:21:02 AM
Quote from: Ratchet_72 on April 12, 2011, 09:08:04 PM
Sooo much for the guys question...nerds.     :crazy:
Does that make you a dumb jock then?
Which was answered on page 1.
carsick
If it really is like a Chevy smack the starter with a hammer while trying to crank it. Just like kids, need a good whack when they are troublesome. Beer usually removes any reservations you may have about this technique. And do remember to have it in park while your girlfriend is turning the key since you're prob'ly under the truck and you already twisted the wires together for the PRN switch and that didn't fix it either. Wait, are we still talking about FJ's?
I'm not convinced its all about the starter motor
just crack the throttle a small amount while cranking and she will fire right up.
jykkeh
BUY 13Y start (yamaha xjr), thats all
FJ12
With all these posts I nearly forgot what the question was, but anyway, my 86 was doing the same thing exactly, for about an annoying year or so of me looking and putting up with it until finally the other day after a few slow cranks it finally stopped turning over for good. And the culprit - that starter relay solenoid thingy that is in the photo's (I would call it a solenoid). Brought a new one, fitted it, guess what, it starts perfect every time now. Fixed, I now love my FJ even more !!
Colin
86 & 93 FJ 'S
Quote from: FJ12 on April 26, 2011, 04:10:07 AM
Colin
I am guessing that the old one worked just fine, messing with the connections cleaned up the contact and dropped the resistance. Too many times I replaced a part and the problem went away. Tested the old part to find it also worked properly. Put the old part back on and ran it for years more. The older the bike, the more likely you will find this. On the other hand....it was a bad part some of the time. For some, they take it apart to trouble shoot, don't really find anything, put it back together and suddenly it works. Don't care why, it works now, let's ride! It's all part of the experience.
indyblue
Quote from: FJmonkey on April 26, 2011, 08:05:09 PM
Colin
Are you sure it was really good?  Like the thread title says "when hot".  By the time you remove it and bench test it is probably cooler.  It could be a hot intermittent condition, so the part may be bad.
Indianapolis, IN `O=o-
1984 FJ1100, 39K mi., custom blue paint, K&N's, jetted, Supertrapps
2005 Pontiac GTO Impulse Blue M6 - gone
2012 Corvette Grand Sport Convertible M6 Crystal Red Tintcoat
1967 Firebird H.O. Conv
Quote from: indyblue on April 28, 2011, 07:01:39 PM
Of course I am not sure, that's why I said "I'm guessing" and included a little later that "It was a bad part some of the time". A bad connection will reduce performance and cause it to heat up much faster. Trouble shoot the easy/free stuff first. Connections fall into that category, just saying.
The problem is solved, that part should be trouble free for many years to come. Back to Kookaloo time.
wakdady
is there a possibility its not the starter at all and maybe too much compression? i.e. tight valves?
my bike does this. all i gotta do is give it a little throttle and it starts right up. but i was curious, so i did a compression check and it read like this;
155 - 165 - 175 - 160.
that #3 at 175 kinda scares me. i do know the valves are on the tighter side of things. i didn't have smaller shims to swap out so it'll have to be redone first chance i get. i'll have to buy shims from Randy it seems. His prices are good.
Quote from: wakdady on May 02, 2011, 01:27:25 PM
Short answer: No.  Tight valves would result in the valve left partially open, thus your compression would be lower, not higher.
weymouth399
My 86 blows 170 to 175 on all four. The 155 would worry me.
I run my valves on the loose side of spec.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
wakdady
Quote from: weymouth399 on May 02, 2011, 01:53:17 PM
Bob W
i got this using the search
"Standard 142psi
Maximum 171psi
Minimum 128psi"
well, if tight valves produce lower compression... and my #3 valves are tight, what would happen if i got the correct shims in there? i want to bring that 175psi down towards 165 ideally, right?
weymouth399
Quote from: wakdady on May 02, 2011, 05:09:39 PM
Bob W
"Standard 142psi
Maximum 171psi
Minimum 128psi"
Put the next bigger shim in it then, but I couldn't imagine wanting less though. :scratch_one-s_head:
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
76 LB80 Chappy
00 KX500 ice/dirt
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
wakdady
you chure? if i'm at .15 in the exhaust, shouldn't i go with a smaller shim to loosen the valve?
