turns over very slowly when hot
Started by karl61, July 28, 2010, 11:21:02 AM
delarbreavous
I had the same problem with my 88
This weekend I Retighted the bolts on the starter
No more "turns very slowly when hot"
Alain
Fluctuat nec mergitur
Quote from: wakdady on May 02, 2011, 05:48:50 PM
you chure? if i'm at .15 in the exhaust, shouldn't i go with a smaller shim to loosen the valve?
Follow the proper procedure and adjust your valves accordingly. Don't worry about 175psi compression, it's fine.
Worry instead about running your bike with tight valves. If they can't close all the way, you can, and will burn them.
All the the higher compression #'s indicate is a build up of carbon. Is your bike running rich? That's a good way to build up carbon.
