Parting out an 88
Started by woodcreekpete, November 22, 2020, 06:38:48 PM
Quote from: tdm34 on April 13, 2021, 12:23:58 PM
Hi Do you still have the footrest plate? if so how much to Akron, OH, 44313
Regards Rob
What side do you need Rob?
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
woodcreekpete
Regards Rob
Sorry Rob - no side plates that will fit an 87
woodcreekpete
Modified Exhaust for a 92
  Stock collector with the left side cut off and welded up. A baffle was welded to the inside to direct flow (blue tape). Yosh muffler has been shortened about 4" to get rid of some rash. Repacked with ceramic fiber (0 miles). A few blemishes on the muffler but overall it looks pretty good. Welded the bracket to it to get rid of the strap. Not too loud - no self-respecting Harley guy would be caught on something this quiet but it's throatier than the stock FJ.
The muffler mounting is correct for 91 or newer but might also bolt up to 87 or older. Definitely would need a bracket for 88-90. Picture shows it on a 92 I just sold - buyer wanted the stock pipes.
Nice cheap way to get a 4 into 1 without the collector hanging down or losing the center stand.
I've run a couple of these on different FJs and the jetting seemed to be fine (42.5 pilots, 115 mains).
$150 US plus shipping
T Legg
Hey Pete I would be interested in the ignition trigger coils and the side cover that goes over them. My cover seems to have broken into many pieces and the rotor impinged on the right trigger coil wearing a groove in to it
                  Travis Legg
T Legg
Hey Trav, the 88/89 uses a different ignition system than your 84/85.
Pick up coil is not compatible
T Legg
Good catch Pat. I don't know what I was thinking.I have already noticed my 86 FJ is different. I could still use the side cover though.luckily despite the groove worn into the trigger coil it is still functioning.
T Legg
PM me your address, I have a pair of pick up coils for you. Is your rotor ok?
woodcreekpete
 Well Travis, that worked out well - I sold the coils I had just the other day anyway. I have the cover - send me $10 and your address and I'll get it on its' way to you.
T Legg
Yes the rotor is good . The right trigger coil got moved inward by the impact and then nicked when Ian rode the bike back to the house. Thanks a million.
T Legg
T Legg
Quote from: woodcreekpete on April 17, 2021, 08:55:58 PM
Thanks Pete .I'll send a pm.
T Legg
woodcreekpete
Sold a bunch of parts lately so it's time to update the list and adjust the prices.
Here goes:
Fork package - legs, wheel calipers discs  $175
Clutch master and slave $40
Handlebar controls $15 per side
Choke cable and knob (x2) $10 per
Complete clutch minus the wire retaining ring $40
Mufflers $60 pr
Alternator$30
Starter $25
Lockset - tank, ign, seat $30
Gauge surrounds 8i-90 x 2 - 91 & up $50 per
88 grey/white sider covers and filler panels $20 per side
Front discs x legal width $40 pr
Scoop trims 88 f up $25 pr
Relay arm 88-90 $25
Fuel pumps $30 per
88-op W/shield $25
Trans gears , forks, complete $50
88 Wiring harness, relays, ignitor $40
R1 - YZF 750 brake & clutch masters with mntg brackets $50
86 Front signals (3 prs) $20 pr
Carb boots $45
FJR master with shorty lever $40
Blue dots - were blue until I polished the anodizing off - good pads $40
38 tooth rear, near new $20
Cobra F1 mufflers 91 and up - very good condition - repacked $200
Everything's in good shape. I'll send an honest description and pics of anything you're interested in.
Reply through your personal email to:
    sleaner@hotmail.com
Shop away people - I need to buy a new helmet
aggopian
woodcreekpete
Sold pretty much everything listed - Thanks.
pict
Quote from: woodcreekpete on August 18, 2021, 05:33:52 PM
Did pretty much everything include the lockset?
1986 FJ1200 1TX
woodcreekpete
Sorry, the lockset has been re-homed. Pete
