Cruise Control/Throttle lock
Started by Ribz0, March 03, 2019, 08:43:50 AM
Ribz0
Hi all...
Not sure if this is the right place for this...
Just wondering what types of manual throttle lock units people are using? My bike had one fitted when I got it but it seems to slip. I have tried to adjust it with no luck so looks like I will need to replace it. Just be good to give the hand a rest on the longer rides....
Bite off more than you can chew... then chew like hell!!
great white
Right now, I'm using a "cheap-o" plastic throttle lock. I think it's a "vista cruise" IIRC:
Works well enough for what it is. I broke my Rh wrist many moons ago, so I need something that lets me remove my hand from the throttle every10-15 minutes to shake some feeling back into it. Any more than that and it just goes completely dead, no feeling at all.
MY Venture has electronic cruise control. If you look at that pic above closely, you can see I'm in the process of fitting it to the FJ. The Venturecruise is essentially a "stand alone" system. All it needs from the bike is 12v power and a speed signal. Luckily, it uses the same reed switch on the Venture as it does on the FJ for speed sensing. The wiring I've parsed out of the Venture harness, so that's easy peasy. All I have left to sort out is some custom throttle cables and then it's just mounting the actuator for the cruise, a couple modules and the vacuum pump assembly.
I'm using an 85 Venture cruise, which only has on/off/set. The 86+ versions have on/off/set/accel/decel. The 86+ also uses a different actuator assembly, which incorporates it's own vacuum pump, but it also makes it bulkier.
Not you typical backyard install, but super sweet once done. "Set it and forget it".....;)
Quote from: great white on March 03, 2019, 11:25:24 AM
I broke my Rh wrist many moons ago, so I need something that lets me remove my hand from the throttle every 10-15 minutes to shake some feeling back into it. Any more than that and it just goes completely dead, no feeling at all....
Have you tried these?
http://rpmracingca.com/proddetail.asp?prod=M%2FC%3ARPMbarend
They don't remove all the vibes, but IMHO they do reduce the high frequency vibes that cause the tingles and cramping..
Ribz0
ok cool... thanks for your input so far...
I think I have a vista on there now.... I have played around adjusting it but cant get it to stay on where I need it....
The Elect system sounds interesting but Im trying to avoid adding anything with a computer.... for an old fart like me... mechanical all the way!!! :biggrin:
Pat... are you using them? do they make a difference? I get the tingles... only on my right hand... so just wondering... and why I'd like to sort out this throttle lock...
great white
Quote from: Pat Conlon on March 03, 2019, 11:45:20 AM
Wouldn't help. It's internal damage in my wrist. Happens when my hand is held in one position too long, whether it be holding the throttle or a coffee cup....
Ribz0
Oh ok... bummer Pat....
I have been looking at the BrakeAway lock... WOW!! that is very nice!! and brake lever release!!
https://brakeawayproducts.com/
A bit pricey... but very nice!! anyone using one?
Ribz0
Great White.... what mirrors have you got on yr bike? Honda?
great white
Quote from: Ribz0 on March 03, 2019, 12:10:20 PM
CBR250R:
They're longer than the CBR600 ones guys usually put on them because the 250 is "thinner" than the 600, so Honda made the stalks a little longer to get the same rear visibility. I'm kinda shaped like a piece of 4x8 plywood, so it gets them out past my shoulders for a completely clear view of what's behind me.
Some guys don't like them because they "stick out" so far, but I'd rather be able to see behind me than look cool. They look fine to me anyways.
The mount plate is too small to get both FJ mount points though. I only have one bolt in the mount, but it holds fine and allows them to swing back easily when hit. Saved them more than once in parking lots. I've come out several times to find one or the other swung back/forward, but undamaged. I friggin hate people sometimes.....;)
Ribz0
ok thanks... yep... I just got a set of VFR750 mirrors from a 90-93 so will get them on when they come... gotta be better than whats on there now...  :good2:
Ribz0
mine is also a later 91 3xw... the fairing is a little different and how they are mounted.... I think those mirrors would stick out allot further... looks good though on yours.... and work so much better I bet...
Quote from: Ribz0 on March 03, 2019, 12:29:43 PM
The CBR250R mirrors work great on the 88-90 models. I had them on my 89. I have found that for the 91 and later models the Suzuki Bandit mirrors work great and look much better than stock mirrors. Photo of Bandit mirrors on mine.
Ribz0
Awesome!!! thanks Fred... Your bike does look the goods...
lol... my throttle lock thread has turned into a mirror thread...  :biggrin: but its all good... so much to do... yet so little time... and even less $$$$ to do it with...
Cheers.
:good2:
I have found that I like this model of the Vista Cruise throttle lock better than the one piece model.
Quote from: Ribz0 on March 03, 2019, 11:56:18 AM
...Pat... are you using them? do they make a difference? I get the tingles... only on my right hand... so just wondering... and why I'd like to sort out this throttle lock...
Yes, I was the first to try them out back in 2010:
http://www.fjowners.com/index.php?topic=2825.0
RPM has since taken over the distribution and has made enhancements to this product and reduced the price.
Win Win.
