Just verifying this is the correct fuel hose routing?
Started by Firehawk068, November 14, 2016, 08:08:50 PM
Since I've never owned a gravity-feed FJ, and I want to make sure that I get this right.
According to the picture on the air-box, this should be correct?
fudge12
Yup. Colossal pain in the ash to get it connected to the tank.
1987 FJ1200
2008 Versys
2002 VFR800
2002 Buell Blast
1986 Honda CM400C
~Dnepr MT-16
1975 Honda GL1000
The best you've ridden is the best you know.
I'm like Netflix, but with bikes.
Thanks for the pictures Alan.... Would you mind if I put them over in the Carb Files Section?
Quote from: Pat Conlon on November 14, 2016, 09:47:49 PM
Go right ahead.
I actually looked in the files section for hose routing before I posted.
I didnt see anything in there.
Quote from: Firehawk068 on November 14, 2016, 10:17:39 PM
Go right ahead.
There will be now thanks to you... :drinks:
Mike 86 in San Dimas
Quote from: fudge12 on November 14, 2016, 09:39:46 PM
After about 25 years of ownership I found slipping 2 x 4 block on edge under the rear end of the tank to support it while slipped my hands in to connect fuel lines made it damn near easy. Laughed at my self for all the times I struggled with this.
Quote from: Mike 86 in San Dimas on November 17, 2016, 06:14:55 PM
4everFJ
I don't route it under the Y-link. Makes it easier to connect to the tank and have never had a problem.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
balky1
Quote from: 4everFJ on November 18, 2016, 03:21:56 AM
I do niether.
FJ 1100, 1985, sold
FJR 1300, 2009
rlucas
Quote from: balky1 on November 18, 2016, 05:01:27 AM
I do niether.
Ditto. Early on in my ownership of the FJ, I replaced that section of hose with a stiffer automotive hose. The routing has always been "wrong" but I've never had an issue. Doesn't fit in the curved retainer very well, though.
flips
Hi All.
As an alternative,I borrowed this idea from Mr Blackstock.
I replaced the stock fuel line with the thicker walled automotive line and replace the stock "Y" piece with a brass "T" .
This allows the split lines to sit a bit lower, or closer to the intake manifolds allowing more space for the main line to run over the top.I have been running this setup for about 4 years now with no issue.
This allows the tank to be raised higher to give more space to easily connect/disconnect  the fuel line at the petcock.
Cheers  :drinks:
Jeff P
Stay rubber side down.
