Carbs stuck in a weird way
Started by JPaganel, September 14, 2016, 05:07:06 PM
JPaganel
So, I went to put the carbs back into the 93.
They are clean, floats are set.
I attached the cable, and found it wouldn't budge. The butterflies were stuck. Pulling and pushing, I found that #2 carb is what's hanging it up. It moves, but SLOOOOWLY. I sprayed a bit of cleaner and got it to loosen a touch, but still kinda stuck.
I have a nasty feeling this may be a shaft seal that disintegrated. Anybody have this sort of thing happen before?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Quote from: JPaganel on September 14, 2016, 05:07:06 PM
Only after someone has soaked the carbs in a carb cleaner dip.
I do have them on the shelf, but for some reason I can't find them on the website. I am searching for them now and will post the link when I find them.
JPaganel
Quote from: racerrad8 on September 14, 2016, 05:22:15 PM
It's not impossible.
This was supposedly fixed by "a professional mechanic friend", and had a seriously odd jetting.
I am starting to think they guy couldn't make it run after his buddy had his hands on it and that's why it was so cheap.
1993 FJ1200 ABS
JPaganel
I sprayed the offending carb with cleaner and now it seems to be OK.
I guess it was just some forgotten gunk. Butterflies snap back like they should now.
I'm going to put the carbs back on and see how it runs.
1993 FJ1200 ABS
