Clutch slave cylinder bore
Started by JPaganel, July 05, 2016, 09:37:33 AM
JPaganel
So, after cleaning out the slave cylinder I noticed that the bore, while appearing to be smooth, is matte rater than shiny.
Is this a problem? Is it going to make it leak?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
FJ1100mjk
I've used a fine grit emery cloth, or wet/dry sandpaper to clean up the bores on a number of clutch slaves over the years. No leaks afterwards.
Procedure info captured here...
http://www.bikers1.com/load4.php?id=411
Iron Balls #00002175
www.ironballs.com
You can even finish it with metal polish (Mother's, Semichrome, etc) for a real nice shine and seal.
Quote from: FJ1100mjk on July 05, 2016, 10:34:07 AM
Keith C and I both had had slave failures on the same day at the ECSR several years ago, so we had a rebuild race, using the emery cloth method to finish the bores.  Not sure about his, but mine lasted for a good long time.
