Replacing clutch
Started by Shane4371, March 31, 2016, 05:24:53 PM
Shane4371
Ordered a new clutch pack from RPM just now,also added a new clutch cover and cap with rubber o ring,
Shane4371
Quote from: Shane4371 on March 31, 2016, 05:24:53 PM
I've got a question pertaining to my upgrade,i understand the wire ring cushion ring get tossed correct?not being a idiot but does the cushion seat get tossed also?
yes.
sounds like you are putting a full size fibre disc in . It will become clear as you reassemble.
http://www.fjowners.com/index.php?topic=1808.msg14307#msg14307
Read this , has pics.
Shane4371
I'm adding a oem clutch spring also.
sounds like the same set up I am running ... 1 extra full size disc in place of the half size and doubled up on the diaphram spring. No slip ever ,.. well except the rear wheel spinning.  :biggrin:
Shane4371
I was gonna try only the new spring first.then try both,in kinda worried it'll cause my slave to start leaking with the added pressure
Shane4371
Quote from: Shane4371 on April 01, 2016, 08:40:44 PM
I rode her after work tonight,she's really slippin bad now,clutch can't get here quick enough,
well if you still have the stock clutch master then I would agree with just one spring.  I did this on another FJ and it was plenty clutch with the extra disc.
I have found You don't need to double up the spring unless you are hauling a lot of weight .. like body mass or luggage.
Make sure you soak the new fibres in oil overnight before installing , or it will be grabby.
Shane4371
Wife loves riding with me,were 370lds together,and yeah it's the original
Shane4371
Quote from: Mark Olson on April 01, 2016, 08:50:34 PM
thanks for the insight,hope I get the clutch parts soon,not worried to much about the install,i am worried about the clutch hcover boots being seized,think I'll ride the bike before I try to loosen those bolt,heat may easy their removal
Quote from: Shane4371 on April 01, 2016, 08:53:33 PM
you are in the double the spring range.  get a Clutch master from an FJR 1300 ... looks just like an fj one so it matches  and your hand wont get worn out in traffic.
as for the slave leaking , I rebuilt mine when I upgraded my clutch and it has not leaked yet ... bout 8 yrs ago now.
Shane4371
Ok,let me look into it,wheres the best place to puchase one?
Quote from: Shane4371 on April 01, 2016, 09:04:29 PM
E-Bay ... get a used one.   Might want to get the brake master too while you are at it.
Shane4371
Quote from: Mark Olson on April 01, 2016, 09:08:07 PM
sorry for all these questions,is the year of fur important,i got a 86 fj
Shane4371
Quote from: Shane4371 on April 01, 2016, 09:11:15 PM
brake master?,in thinking clutch master cylinder
