GSXR Rear Wheel mod spacers
Started by chocker, October 28, 2015, 12:03:42 PM
chocker
Hi Guys,
I did the rear wheel mod and everything seemed to be good. I realize now that I used spacers that were approximately 2.5mm each thinking that the 4mm width was the total for both spacers. Is it 4mm for each spacer? If so, I am not able to find a spacer with a 20mm inner diameter and approximately 4mm wide. Would anyone be able to tell me where to find one if that is the case. I live in Montreal Quebec Canada.
Thanks,
Mark
This is the file that lists the 4mm washers as spacers. http://www.fjowners.com/index.php?topic=3380.0
0ne 4mm washer installed on each side, next to the swing arm.
I found my washers at an ACE Hardware store.
chocker
That's great, thanks. I just need to find a place closer to me in Montreal. I went yesterday to a hardware store and I got two spacers but they are a little thinner at about 3mm. Hard to tell the exact width with a tape measure because it is small.
Mark
Quote from: chocker on October 29, 2015, 02:21:35 PM
Mark
Mark, use a couple of Toonies to measure thickness, each one is about 1.8MM so two will get you 3.6MM
https://en.wikipedia.org/wiki/Coins_of_the_Canadian_dollar
chocker
Hi,
that's a great idea and I happen to have two toonies in my pocket as I read your reply. One seems a little thinner though. Either way, the spacer is the same thickness as the coins. When I think about it, the spacers I used initially were exactly the same size as the two I just bought. I know because luckily the spacers are stamped with part numbers and they are the only size that would fit that I found in the hardware store. The whole reason that I thought they were too thin is that when I tightened the axle nut, the cotter pin slot came out slightly more then with the stock wheel.
Mark
Now make sure the rear wheel is properly aligned, a little pinch of the swing arm is not bad, poor alignment is bad.
chocker
Other than that, it all seems good with the alignment. I do see that the links on the chain are getting a little harder to bend than before. I have been lubing on a regular basis but I haven't changed the chain so that could be another issue altogether. I think during the winter, I'll get a new chain. The sprockets were changed when I did the wheel mod so they are still good.
Mark
scotiafj
 :hi: Mark thats exactly what I found with my spindle ..thought the spacers might be too thin but Ive done over 1000 miles since doing the mod about 3 weeks ago and every things ok ..  :good:
