clutch wont work
Started by JOMPPA10, August 01, 2015, 05:50:09 AM
JOMPPA10
HI
installed new ebc clutch kit and by trying it with cover off clutch lever worked fine
i didnt try to shift gears
next i put cover on and change oils to engine
then i run engine warm
next i tried clutch lever , it was kinda sticky and hard to use
and it was impossible to get gears on.
so how ican proceed?
When you say a clutch kit, did that include new fiber plates/rings? If yes, then did you soak them over night in oil? When you tried the clutch lever with the cover off, was the clutch fully assembled, spring and all? Less important, what weight oil did you fill with?
JOMPPA10
Quote from: FJmonkey on August 01, 2015, 07:46:46 AM
yes new fiber plates/rings and spring and idid soak plates few hours before installing.
clutch was fully assembled and spring in right torgue
oil is motul 5100 10w40
hope that helps to diagnose the problem
Hard or difficult shifting is normally caused by the clutch plates not fully disengaging. The plates are sticking or dragging and the friction is preventing easy shifting. The new clutch pack could be too thick, or the clutch slave may not be giving full travel. I would bleed the clutch hydraulics. This allows you flush out any old fluid and remove any air that might be in the system. When trouble shooting I like to do the easy/simple stuff first.
Can you roll the bike around in gear with the clutch lever pulled in?
JOMPPA10
Quote from: FJmonkey on August 02, 2015, 10:46:42 AM
yes ican roll bike, but now i remember: i pulled short part from part that moves clutch off and change
o-ring coud that cause to get air to clutch?
Quote from: JOMPPA10 on August 02, 2015, 12:39:39 PM
Which "short" part in this diagram are you talking about?
http://www.ronayersmotorcycles.com/fiche_section_detail.asp?section=3937443&category=Motorcycles&make=Yamaha&year=1986&fveh=177129
JOMPPA10
Quote from: FJmonkey on August 02, 2015, 01:14:30 PM
part number 27
Quote from: JOMPPA10 on August 02, 2015, 09:34:24 PM
part number 27
No, that is an internal part along with the o-ring and it will not affect getting air into the hydraulics. Report back after bleeding the hydraulics.
JOMPPA10
Quote from: FJmonkey on August 02, 2015, 11:18:13 PM
part number 27
hydraulics bleeded and clutch working fine i ewen burn some rubber in my garage :yahoo:
thannx fj monkey :drinks:
Happy to help, now ride it and enjoy life behind bars...
CutterBill
Quote from: JOMPPA10 on August 03, 2015, 02:20:16 PM
...i ewen burn some rubber in my garage :yahoo: thannx fj monkey
Now THAT's how you ride an FJ!    :biggrin:
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
