i fuckin hate upholstery
Started by theLeopard, July 19, 2015, 05:21:56 PM
theLeopard
bike need work.
pls call for manshed day.
mark I broke my phone send ur number  again.
1992 FJ1200
Quote from: theLeopard on July 19, 2015, 05:21:56 PM
bike need work.
PM sent
Antonn3
you will get it done theLeopard....from what I see, is the material on the heavier side? Might want to try thinner.
Don't try to use the tacks.. almost impossible.....a cheap electric staple gun works fine.. but use the  smallest staples (1/4").
Did you try starting at each end first? I found if you start in the area that you would normally straddle the seat and pull side to side (staple as you go along) in that area first  and then progress forward and then back from that area works best.
When you hit a contoured area, use a heat gun to help the vinyl conform and staple as you go along.
Hope that makes sense?
Good luck
Tony
This has to be the funniest post of the week :lol:
At least you had the good sense to practice with some god awful colored material, kudos.
I like the Leopard spots on the air scoop myself.
krusty
The trick with recovering is to get the vinyl really warm and s - t - r - e -t -c -h it. I did my fj11 seat earlier this year and I left the vinyl in the sun for about a half hour before starting. I started in the middle and gradually worked towards each end. If I felt that the vinyl was resistant then I would leave it in the sun for a little while and then continue.
This is it.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
krusty
Forgot to mention, it was summer sun!
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
theLeopard
1992 FJ1200
Shane4371
Did my seat last night.not that hard just gotta work with it. :
CutterBill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Shane4371
Yeh.it wasn't to bad.you just gotta work with it.I'll change the seat them again I just wanted to try diffrent themes.playing around.
