2015 Plans for the FJ
Started by Mark Olson, December 31, 2014, 04:47:09 PM
Now that the New Year is upon us it is time to do those repairs and modifications we have all been slacking on.
This is my list , What is Yours?
1. Rebuild transmission , I may even take pictures and do a write up. :mail1:
2. Change fork seals
3. Rebuild carbs
4. Repaint engine
5. Polish up forks
6. normal spring Maint . Change fluids , inspect connections , lubricate all brgs, chain ,ect.
7. Repair faring turn signal mount.
8. Clean and polish entire FJ.
That should be enough to get through winter.
roverfj1200
Best part will be the test ride I think.. :good2:
1988 FJ1200
Richard.
That's quite the list Mark.......................Should keep you busy for sure. :drinks:
My list right now is: :mail1:
(1) Fix oil leak at cam chain tensioner gasket.
(2) Check/adjust valve clearance
(3) New rear tire
(4) Clean and Lube chain
(5) Change oil/filter
Mike 86 in San Dimas
Take it to the WCR. Oh and maybe a carb re-build.
Quote from: Firehawk068 on December 31, 2014, 06:10:38 PM
(3) New rear tire
Hey Alan , looks like you have a list going as well. Good luck with it all.  :drinks:
Quote from: Mike 86 in San Dimas on December 31, 2014, 06:15:55 PM
Yeah Mike , defiantly see you at the WCR if not before then .
I plan to get down to the LA area and see my brother in law, He is long overdue for an "ass whoop'in ".
Then ride around a bit .
My list for the near future in 2015 is....
Fix my turn signals not working issue.
Re-paint the lower cowling.
Powder coat the grab handles and the Vibranators.
Flynt
Quote from: Mark Olson on December 31, 2014, 04:47:09 PM
What is Yours?
Ride it like I stole it...  repeat.  About 15K on the 1350 now and it continues to run like a hose.  I'll probably wax it a few times.  I'm almost due for another oil change, so that will happen soon enough.  I also have a NOS main fairing for Wiz, but not sure I have enough time to change it given the year round riding we enjoy here in Cali.  It is just a spare I guess...
Happy New Year everyone.  :drinks:
The short list is:
Get saddle bags
Rebuilt the top end
Change the rear shock spring
Clean polish and wax
Attend the Black Hills Rally
Take one or two longer trips going no particular place for no particular reason.
Do good when I can
Chin fairing repair
Tank dent removal
paint scheme change
top case install
fine tune suspension settings
Yah my list would take me hours just to write it up. I just hope to get some of it done. Before I start my month long sabbatical on 5/20/2015. And hopefully still have some money left to enjoy it. Hope to get the turbo bike at least done enough to take it along on the trip.
Oops! Forgot the custom Corbin seat...
You guys are killing me... I need to fix my cracked case, weld up a new upper shock mount and transfer my entire bike over to a new frame... All the other stuff is just fluff... Lazy Bastards!!!  :ireful: :ireful: :ireful: I hate you all..  :diablo:
I also look forward to seeing and riding with you at the WCR....  :drinks:
Steve_in_Florida
Monkey,
I feel for you, brother. Really.   :empathy2:
FJScott got to see the extent of (some of) my projects the other day. Like giantkiller deerkiller, it would take a while to type up.
`90 FJ-1200
`92 FJ-1200
IBA # 54823
The FJ is competing with another toy for what gets what this year...
Although it does need:
Leaking seals replaced
Motor Mounts (including unsticking the top left "solid" mount
Tires
Chain and Sprockets (nearly 40k on current set)
Headlight wiring cleaned up
Maybe:
RPM Fork Valves and straight rate springs
Happening for sure:
Full repaint of the plastics and tank
