cleaning brake calipers
Started by andyoutandabout, November 25, 2009, 11:05:05 PM
would one use WD40 as a make do, or is it best to use the right stuff?? I have much faith in WD40 and bathe in it everyday. Does wonders for squeaky joints.
threejagsteve
Quote from: andyoutandabout on November 25, 2009, 11:05:05 PM
If you got squeaky joints, you need to roll 'em tighter!
Spraying straight Simple Green, scrubbing with an old toothbrush, and rinsing with plain water works wonders.
If ya wanna use WD, better pull the pads first!
"If you wanna bark with the big dogs, you can't pee with the puppies!"
RichBaker
The outside or the inside? Any cleaner is good for the outside, but I was always taught to use ONLY brake fluid or denatured alcohol for the innards..... anything else could cause problems down the road.
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
threejagsteve
Quote from: threejagsteve on November 26, 2009, 01:31:48 AM
Where:
S(c) = compression strength of the filler material
S(t) = tensile strength of the sleeve material
T(r) = radial torque
F(t) = tensile force,
F(t) = T(r) when T(r) = S(c)/2, and  F(t) = S(t)/2
This is over thinking it me thinks.
threejagsteve
Quote from: andyoutandabout on December 12, 2009, 05:56:08 PM
The wheels keep turning whether I want them to or not!
Remind me never to go drinking with you.
threejagsteve
Quote from: andyoutandabout on December 13, 2009, 12:38:10 AM
It would likely read like the script for Very Bad Things 2: Very Bad Things on FJs!
Actually, simply using those joints for their indended purpose generally does an excellent job of reducing any instances of over-thinking things.
threejagsteve
Quote from: andyb on December 13, 2009, 08:08:20 AM
WARNING: May lead to excessive and/or exuberant polishing.
