Just received and installed the RPM Smoked tail light.
Started by aviationfred, December 18, 2013, 06:18:10 PM
Just installed the new RPM smoked tail light with integrated turn signals on my 87' 1TX. I am extremely pleased with the result.
The OEM stock tail light
The RPM smoked LED tail light with integrated turn signals.
roverfj1200
1988 FJ1200
Richard.
Isn't that just beautiful. Dazzling array of modernization. I want one, BAD!
soundmindryan
You must live on wooded acreage, like me.
Your garage floor looks EXACTLY like mine!  :good2:
No matter how much I sweep up the leaves, every time the garage gets opened, more leaves blow in. They must not like the cold. :ireful: :flag_of_truce:
Ryan
Ryan McCollum
Tulsa, OK
'89 FJ1200 White & Silver
'90 Yamaha Venture Royale
"I visited a scientist who had a helmet with magnetic fields controlled by computer sequences that could profoundly affect your mood and your perceptions."
-Douglas Trumbull
Quote from: soundmindryan on December 19, 2013, 09:56:23 AM
Ryan
I've never understood that concept... but it's true!
I was just doing some cleaning out there for the upcoming NYE and Super Bowl parties, and there were a LOT of 'em.
There's not all that many trees right around here, though.  :unknown:
TexasDave
Vsekvsek
Do those things just plug right in? I was gonna do this mod this spring
89 fj
09 wr300 husqvarna
Quote from: Vsekvsek on December 19, 2013, 12:46:35 PM
Yep, it is a direct replacement for the stock light.
FeralRdr
One thing to note about Randy's tail light kit, is that it doesn't come with any resistors.  This is only an issue if you want to retain the OEM flash rate and/or the self canceling function.
If you do decide to install resistors, I would recommend avoiding resistors of this type of design:
In my case, one of the resistors in the pack I bought, had a broke wire inside the black (shrink wrapped) section.  The local shop that I purchased them from, had a replacement pack, but here in lies the warning. The replacement pack also had a resistor with a broken wire in it.  they gave me the good resistor out of that pack and I ended up reinforcing those sections of wire by using a small nail and shrink tubing as a splint.
Eventually I installed Rizoma rear turn signals to work along side the integrated turn signals and they came with these type of resistors:
This made the original resistors redundant and allowed me to remove them.  The nice thing about this type, is that you don't have to hack up your wiring harness.  Also, though the above are the ones that come in Rizoma's kits, similar ones are available from various sources.
