Manshed Therapy January 20th for Queenslanders
Started by The General, January 04, 2013, 12:02:12 AM
Quote from: Stainesy on February 02, 2013, 01:47:52 AM
Quote from: ribbert on January 31, 2013, 06:46:56 AMChecking anything on a bike anytime is a good idea but if they are sufficiently lubricated and the grease is replenished periodically there is no need to check them. Nobody ever removed the kingpins (hardened shaft in a bronze bush) from their car to grease them, they just pumped new grease in. The nipple also guarantees 100% coverage.
I'm a bit sceptical about the nipple guaranteeing 100% coverage.
There's a rebate in the centre of the bush which acts like a mini reservoir and fills first, then like all hydraulics, forces it out to the narrower sections with higher resistance under equal pressure leaving no voids.  I re-greased mine recently after about 15k and the old grease was force out uniformly right around the bush and out both ends in similar quantities.
I guess being a mechanic I view things a little differently when it comes to ease of maintenance and unnecessary work. While I do enjoy tinkering with the FJ and find it therapeutic that doesn't extend to needless dismantling if there is a way of avoiding it and I'm not convinced there is a need to visually inspect them if the grease is replenished regularly.
Either way this is not a biggy, as long as they're done. How you choose to get the grease in there doesn't really matter.
FJSpringy
Quote from: ribbert on February 02, 2013, 04:35:43 AM
Having battered my way back in there this morning I am even more convinced on the nipple idea is the way to go, the mount is in perfect condition with heaps of cleanish grease from the last time I did the job.
To be honest having done one side this morning I am over it and not looking forward to the other side as it is 9.30 in the morning 30 degrees C already and it sucks  :flag_of_truce:
If I had put the nipple in last time I would be finished and having breakfast as I would have to have only eased off one nut and pumped in a bit of fresh grease.
Here is the rebate Noel talks about it is quite wide and deep.
Dave
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
FJSpringy
well that's the right side done, won't bore you with the left hand side  :flag_of_truce:
I have kleptomania,
92 FJ1200
