Ignition timing cover is cracked
Started by Charlie-brm, August 06, 2013, 02:52:59 PM
Charlie-brm
Straight to the point, it is cracked across the face from 4 o'clock to 6 o'clock and all the way back through its thickness along the bottom rim.
There is a small amount of oil accumulated there but maybe that is blown back there from somewhere else forward of the cover.
Yamaha microfiche calls this the oil pump cover but it is the ignition timing cover, right?
I haven't taken it off but it seems to be made of plastic, not die cast metal.  Would a clean prep and JB Weld or similar keep this from getting worse?
Other suggestions? I see them online rarely and the price is over $100 and I don't see the rubber ring gasket included in that.
1979 XS750SF - 2005 to 2012
There should be no oil present behind the cover unless the crank seal is leaking.
It is aluminum and not plastic.
The gasket is not included, nor are the bolts.
I have several good used ones that I removed from the race cars.
Shoot me an email if you want a used one; randy@rpmacingca.com
DarthLoser
I bought one a couple weeks ago, installed it yesterday and it looks great.
Thanks Randy!!!  :good2: :good:
