Magura clutch cylinder
Started by keand3, July 30, 2013, 12:58:03 PM
keand3
Hi guys!
Has anyone here had any experience with Magura cylinders? I am looking into replacing my clutchline and clutch master cylinder.
Have spotted out a Nissin Radial in gold (19mm piston), as awsome as it looks, I am afride it might "brake" the look of the bike, with the brake cylinder beeing black with silver handel..
The Magura is, from what I can see, a bit more expencive then the nissin. The one I have been recommended is at approx. $345. For that amount I might as well invest in a Brembo cylinder instead, but I woulden't think there is a need fopr any high end cylinders. It's not like I'm out on the track everyday, but I do like quality, and prefer quality over price..
So before I make up my mind and choose, I would like to se what information you guys have on the Magura.
Thanks guy.
Ken
Goetz
you can get a black nissin from dime city cycles for 145... tho their user interface is a pita
I bought a brembo / r6 16mm radial brake master under  $100.. so had to find a matching style radial clutch mc, went with a kawasaki nissin one , pretty much all the same if you get the remote resevoir type for about $60 on ebay usa
Heliflyer 88
You could always just paint the lever. That's what I did when I put the FJR brake master on my 85. I used Krylon satin black. Looks just like stock!
Goetz
My clutch master has a 14mm bore, I noticed a distinct improvement in feel over stock (and no leaking hydraulic fluid on myself), but now i can tell that the slave needs replaced, and most likely the lines in between as well. Next project.
keand3
Quote from: fj11.5 on July 30, 2013, 06:08:27 PM
You did? Were?
Have looked at the Kawa nissin to and it looks nice. Seen a lot of Kawa 1400 M/C which is 19mm to.
Quote from: Goetz on July 30, 2013, 01:14:51 PM
Thaks, man. I'll be sure to check out their website.
Got the mc from a wrecker a couple of hours from here , I didn't even know it was a radial till it arrived :good2: ,yep the 1400 concourse mc for the clutch is what mine is from, some of them have a rectangle style res fixed on, like a urine cup but diferent  :lol: clutch side came from ebay usa
