Front Rotor Question
Started by Sabre093, July 25, 2013, 12:27:49 PM
Sabre093
Does anyone know if my 86 bolts will work on 89 rim and when I powder coat rims should I thread some into rim as to keep threads clean for re-assembly, I'm going to replace all the bearings that's a no brainer on my part.
Thanks
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
Quote from: Sabre093 on July 25, 2013, 12:27:49 PM
Thanks
You'd have to remove the bearings for powdercoating anyway, otherwise the grease runs out of them when the powder gets baked on.
On the ones the I have had done, they just taped off the bolt holes, and they were fine.
AFAIK, the bolts are the same on all models, but the '86 rotors definitely won't fit the '89 rim.
I used the bolts from my 84 discs when swapping over to 89 wheels :good2:, yeah, id block the bolt holes , just cover the mounting face, as you don't see it once the disc /rotor is fitted
Thmsdoyle
I'm with not for lib. I didn't block mine off, but I did tap them all out after powder coating. I used my old rotor bolts from my 84 rotors.
Tommy D.
FJ Flyer
Definitely tape over the holes and where the bearing seats.  And the edge of the rim if you want to polish it.
Do yourself a favor, get new bolts for the rotors.  Not that expensive.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Sabre093
I am doing that...and i'm yanking and replacing the bearings.
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
