Headlight adjuster U-joint
Started by JPaganel, July 02, 2013, 07:07:15 PM
JPaganel
My initial attempt to find this failed. Apparently, these things break on every bike and there aren't really replacements.
I remembered that RC boats and cars use very similar joints. I measured the adjuster shaft and found it to be 5mm in diameter. Researching the joints I found they come in 5mm, but only on one end. The other end is usually a 4mm. So, I got one of those. It's slightly larger than the original, and it's stainless steel. It also has set screws.
I am going to try to cut the 4mm end into a square hole to match the original. So far, I'm thinking dremel. Any other suggestions?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Quote from: JPaganel on July 02, 2013, 07:07:15 PM
Keep searching, a member used a 1/4 drive U-Joint to fix this.. It has been done...
cyclenutk75
Here it is:    http://www.fjowners.com/index.php?topic=7513.0GT
Just whipped one of these up myself yesterday. Works great.  Windancer - thanks for sharing.
GT
Simplicity of character is the natural result of profound thought.
I know it's annoying to have something broken on your FJ, but really, how many times do you need to adjust your headlight?
I can't remember the last time I touched (or needed) that adjuster.
Hooligan
