Gixxer Rear Sprocket
Started by Sabre093, June 27, 2013, 05:28:50 PM
Sabre093
So i'm setting up for the comversion , what combo is everyone running..I'm using 18/38 on my 16's but I hear i'm going to have problems locating a 38 for my 93 Gixxer rim..what's my options out there
Thanks...Big shout out to AviationFred for his help.
Grabbed Bridgestone Battleaxe tires from a demo model less than a 1000 kms on them 120/70017 frt....180/55/17 rear..100$
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
fj11.5
I'm using 18/38 on effie the 11.5  :good: with 5.5"  gixxer rear,  found a few on ebay, steel if you can, but I've used An alloy one while using the first wheel swap on the 4.5" rim,  with no problems, ,
84 Fj1100  effie , with mods
Quote from: Sabre093 on June 27, 2013, 05:28:50 PM
This is the sprocket I am running on mt 92' gsxr750 wheel. should fit on your 93' wheel
http://www.ebay.com/itm/JT-Rear-Sprocket-38T-Suzuki-GSXR750-1990-1992-/321106738641?pt=Motorcycles_Parts_Accessories&hash=item4ac373fdd1#ht_1691wt_1161
craigo
Yep, that's what I'm running on my 90.
CraigO
CraigO
90FJ1200
Quote from: aviationfred on June 27, 2013, 05:47:51 PM
Fred,
That looks like an aluminum sprocket -is it?  If so, be aware that the FJ has eaten many-an-aluminum-sprocket in it's day.  I've seen more than one picture of an aluminum sprocket with NO teeth left, just a semi-smooth outer disk edge.
If not, and it's steel, then let this be a warning to those that consider the aluminum option, eventually conventional wisdom suggests that the FJ will eat it.
Edit, I just took a closer look at the listing, and it did call it out as steel.  Reading IS fundamental....
Same sprocket I've got. Still have it and the new chain sitting in the drawer to fit sometime.
Sabre093
X-Ray...I'm looking for the 2 washers from rear wheel mod...where did ya get them..
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
Quote from: Sabre093 on July 10, 2013, 07:37:57 PM
Pardon, don't mean to but in. The washers I used for my GSXR conversion were off the shelf Ace Hardward washers. Out of memory 20mm or 3/4" diameter washers (I might be wrong there) . As a note in the final adjustment left or right I think I also used one of the washers from the old FJ rear. Depending on the spacers you don't always end up with equal thickness of washers on each side.
On my 92' GSXR wheel mod. I used the same off the shelf ACE Hardware 20mm ID washer as George says, I used 2. 1 on each side right up against the inboard side of the swingarm.
You wouldn't believe but I had a heap of these s/steel washers sitting in a btl in the shed. 4mm thickness, 1 each side, and the chain lines up near perfectly. Photos #14 and 15 in my link below show them fitted,
Regards
Ray
WhiteBeard
I have loads of extra 4mm washers as well, if anybody's interested.
I'm in Sweden, but shipping a couple of washers shouldn't be more than $3.
Nat
Sabre093
I will keep looking here so far nothing,I'll hit paydirt somewhere i'm sure...lol
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
jamesearthdrum
Quote from: Dan Filetti on June 27, 2013, 08:56:24 PM
Fred,
Been there, done that!  :dash2:
peace:)james
"we often refuse to accept an idea merely because the tone of voice in which it has been expressed is unsympathetic to us."
~~~friederich nietzsche ~~~
Bet that aluminum sprocket with the nubs (ex teeth) made a hell of a racket every time you gave it some gas.
eeshed
Thanks for the great information. I'm on a mission to collect all the parts for a gsxr wheel conversion. I will need a 38 teeth sprocket. However, I would like to get a steel, and not aluminum.
I wasn't clear if the link above is for a steel or aluminum. Could you please clarify? If it is aluminum, any suggestions for where I can get a 38 teeth steel sprocket?
Eyal
