Everything is relative.
Started by JPaganel, June 13, 2013, 06:58:00 PM
JPaganel
So, since I'm working on getting fairing mount mirrors, I got a pair of bar weights. I just picked up a set that was the right size, they were marked as being for a YZF600.
I swapped my bar-end mirrors for them. Holy crap. THERE IS ALMOST NO VIBRATION!
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
 Cool, no more numb fingers :good2:  , when I tried mine without oem weights I also tried alloy bar ends, baaad move,  , now using stainless steel bar ends, slightly heavier than the original
fintip
Haha. Surprise, they're there for a reason.
The next step: a pair of 'vibranators', tuned end weights that resonate to the engine's frequency, cancelling out vibes. Randy sells them, had them made.
fjowners.wikidot.com
-ZAMM
IBA:54952
JPaganel
Oh, I know they are there for a reason. The previous owner didn't.
1993 FJ1200 ABS
Quote from: fintip on June 13, 2013, 10:41:46 PMHaha. Surprise, they're there for a reason.
Riders,
I got a set of Vibranators for my FJ1100, early on.  Riding long and hard used to leave my hands buzzing, but this problem vanished the first time I rode with them installed.  I needed a pipe wrench to remove the old bar ends, but the new parts fit very well.  They look fine.  I have only good things to say, for the Vibranators.  I also added  set of foam hand-grips, which also made things more comfortable.  I used a thin coat of Shoe-Goo around the handlebar grip area to install the foam hand-grips, and once that stuff dries, the grips will not slip or rotate on the bar.
