choke knob screw
Started by Tapartacus, June 05, 2013, 09:58:56 AM
Tapartacus
So I went and lost the screw that holds the choke knob on my 92. Any ideas? do I have to purchase a whole new assembly? Randy are you out there?
Andrew
92  FJ1200
89  FJ1200
FeralRdr
2.5 x 6 mm.  You can order one from any Yamaha dealer.  Though it isn't listed on the FJ's fiche, it is listed on the FZ750's.  A cheaper solution would be to go down to the local Hardware store. Yamaha will give you the opportunity to pay around $4.00 for that darling little screw, but ACE Hardware had them for about .30.
Hope this helps.
Tapartacus
Thanks FeralRdr, what year FZ750?
Andrew
92  FJ1200
89  FJ1200
I think I have few in the garage, PM me your address if you can't find it local...
FeralRdr
Quote from: Tapartacus on June 05, 2013, 01:27:28 PM
Andrew
Sorry Andrew, should have included that earlier.  '85 is the year.  To be clear, you should be able to find those at your local hardware stores for about .30; the OEM one will set you back around $2.00 to $4.00 (USD).    Also, I strongly recommend using some locktite on the replacement one.
Tapartacus
Quote from: FJmonkey on June 05, 2013, 07:46:15 PM
Thank you Mark, thank you FeralRdr, I found it on Partzilla for 1.75 and 1.75 to ship, Will save me time running around as we don't have an Ace hardware here.
Andrew
92  FJ1200
89  FJ1200
crzyjarmans
Quote from: Tapartacus on June 06, 2013, 12:48:35 AM
Andrew
i had the same problem not long ago, Ace hardware didn't have one, but found a little hole in the wall hardware store that had them, bought 3, so to have 2 spares, cost a total of 13 cents for the 3 screws, Glad i got 3, cus just a week later it fell out again, So this time I used a little lock-tight, All good  now
Shawn Jarman
Persistant
Had same problem when I went to reassemble my fairing once I had located all the parts....except that damn screw!!  Went all over town and finally retapped the hole to a standard common size....
Andrew
RichBaker
Quote from: FeralRdr on June 05, 2013, 09:48:07 PM
Andrew
If you use loctite, use Purple-for small fasteners..... Otherwise, you may not be able to get the screw out when you want to.
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
