Is ABS cement pretty much ABS in some solvent?
Started by JPaganel, June 02, 2013, 06:18:46 PM
JPaganel
It sure looks like it when it hardens.
I decided to practice my gluing skills on the inner panel that exploded into pieces and I think I did pretty good - it feels very solid. One piece was missing, so I covered that spot in foil and poured some ABS cement in there, and now I have it filled in. I let the first thin film dry and I've been gradually adding to it. A couple more times and I will have the whole thickness filled, so I can sand it down level and it would be whole again.
That's nifty.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Quote from: JPaganel on June 02, 2013, 06:18:46 PM
That's nifty.
I seem to recall using ABS grindings or small chunks with the glue to fill in larger areas. The glue has solvent so it shrinks when it dries. The filler reduces this effect. Not sure about strength.
