later year gas tanks?
Started by Antonn3, May 31, 2013, 09:18:27 AM
Antonn3
Hello, on the later year gas tanks, what is the small "nipple" or tube that extents out from the rear of the tank, located below the forward part of the seat ?
Its only visible when you remove the seat.
I'm replacing my FJ1100 tank to a later year.
Thank you
Tony
jamesearthdrum
Tank vent, should have a rubber hose that goes back and down the center of the bike in front of the battery to just below the lower shock mount.
james
peace:)james
~~~friederich nietzsche ~~~
Antonn3
Travis398
The tank vents through the gas cap, the hose is an overflow hose. if you overfill your gas tank it runs out the hose instead of spilling all over your gas tank.
jamesearthdrum
Thanks for the clarification Travis.  :blush: Even more important why you need to put the hose on it!  :good:
peace:)james
skymasteres
On my tank there is a plastic fitting under the front portion between the two C shaped peices. What is this for?
(1990 FJ1200)
Not having seen under a californian model fj tank, I'm guessing its for the emission canisters  :scratch_one-s_head:
