84 main needle identification before I buy pods
Started by Charlie-brm, May 17, 2013, 10:09:48 AM
Charlie-brm
Just want to know if this is the stock needle in my carbs on a 1984 FJ1100. And if so I am assuming they are not adjustable.
From poking a finger in there I am guessing it's almost a half inch between that plate and the bottom of the slide.
That being the case, should I plan on getting adjustable needles to go along with buying the UNI dual pods? Any alternatives to suggest to have good running with the pods?
My exhaust is stock. The carbs are stock.
1979 XS750SF - 2005 to 2012
Quote from: Charlie-brm on May 17, 2013, 10:09:48 AM
The plate is supposed to sit on the bottom of the slide. If it is raised up 1/2" then something is holding it up there.
You need to pull them apart and see what you have in there spacing the plate up. You can then shoot a picture of the needle and read the number on it as well to determine what you might have there.
This needle deal might explain the running problem you talk about in the "float height topic" earlier.
Charlie-brm
Thanks Randy. The bike was running fine last year so I am not suspecting the needles, but I am getting tired of fighting the air box and want pods. I saw an installed pair today - nice.
I would be afraid to go at those little screws on the plate with a Phillips because if they are JIS I may only get one try. I'd like to find a source of a JIS assortment for that reason.
Quote from: Charlie-brm on May 17, 2013, 09:12:56 PM
Randy has a better solution, ditch the JIS and convert over to HEX SST. http://www.rpmracingca.com/proddetail.asp?prod=carbkit
I really like having these on my carbs, much easier to work on now.
Thanks Mark,
I tried to post that link from my cell phone last night but I could not get it to work.
Oh , as side note, the picture does not show all the fasteners, just a small portion. Randy, fix that picture so your customers see how extensive your kit is.
Quote from: FJmonkey on May 18, 2013, 06:29:32 PM
Both photos are on the website You just have to look through both pictures.
FJ11-12/XJ12/XJR13 Carburetor S/S Screw & O-Ring Kit
Quote from: racerrad8 on May 18, 2013, 07:26:22 PM
Same pic... Try again...
Quote from: FJmonkey on May 18, 2013, 07:29:55 PM
Hit the "Next Photo" button and you will see both pictures...
Quote from: racerrad8 on May 18, 2013, 08:03:07 PM
Got it, one pic will be better (IMHO), Don't make em' look for it, just saying..... Some of us lazy $#@s don't look more than the first pic...
Quote from: FJmonkey on May 18, 2013, 08:15:05 PM
So what do you do with the rest of the magazine?!
Quote from: fj1289 on May 19, 2013, 06:55:40 AM
I just get it for the insightful articles....Really.... :blush:
