Horn
Started by Tapartacus, May 15, 2013, 04:58:17 PM
Tapartacus
Can someone tell why when my horn is hooked up normally it sounds like shit but when I unhook it and supply power directly from the battery it almost deafens me. Electrical in not something I'm good at.
Thanks
Andrew
92  FJ1200
89  FJ1200
Most likely its not getting full 12v wired in,  or a bad earth,, if you connect a relay inline the horn will work perfectly
Tapartacus
Ok I've heard of putting in a relay but where? again not electrically inclined. Please talk slowly. Lol Could it be the switch?
Andrew
92  FJ1200
89  FJ1200
Relay uses the original horn wires to switch it on, and a new power and earth to it, , I'm sure they're are pics in the files section of how to wire it in, ,
Tapartacus
Thank you! Yes I bought a 30 amp relay and followed a diagram on line. Attached horn wires to relay then ground wire from horn to battery. Then 10 amp inline fuse from pos battery terminal to relay then to horn. Now I'm wakin up the neibours!!
Thanks
Andrew
92  FJ1200
89  FJ1200
No worries mate,, now if you want to deafen them too, fit pod filters ,and an airhorn in the vacant space  :biggrin:
Riolongo
I've got the same problem with my horn, looks like I'll be doing the same, thanks for the tip.
