Motor Mount - rear bolt
Started by TheLightsAreOnBut, April 16, 2013, 07:51:52 PM
TheLightsAreOnBut
Hi, I looked at the Parts Microfiche file on a 91 FJ1200
I removed the engine for my trike project but decided be easier to mount if I used the frame.
I have it back together but there is about 0.150 space between the motor and the frame on the rear 1/2" long bolt.
Seems like there should be a spacer in there, I don't remember taking it out and the Parts Microfiche does not show one.
Is there that much of a gap?   Is there suppose to be a spacer?  one spacer or on both side so motor centers in frame.
I greatly appreciate your info.
TheLightsAreOnBut
I should have worded that different.  The long bolt (about 8 inches long)  about 1/2inch OD bolt.
Is there suppose to be a space between the motor mount and the frame?
baldy3853
Not sure but on the back I can't remember if its a spacer similar to the front engine mount or it is rubber mounted
