Auxiliary lighting ideas?
Started by ktmaha, April 15, 2013, 10:04:38 AM
ktmaha
Any cool ideas out there for some additional lighting? Pics?
1973 Yamaha CT 175
1986 Yamaha FJ 1200
1996 Yamaha TTR 90
1991 Miata @ 8psi
Quote from: ktmaha on April 15, 2013, 10:04:38 AM
I use these for conspicuousness (is that really a word??) but not so much to brighten things up.  I had good results adding a relay to my OEM lamp for better night vision.
Here's the switch - located above the start switch - for the aux lights (again, relay is a must):
'94 Yamaha WR250
FJ Flyer
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Bob
I used a cheap set of surplus halogen lights and replaced with 55W bulbs with a 12 LED bulb.  Mounted on the frame.
Picture is with the halogens. LEDs are bluer and about half as bright; two 55W light's was too much with heated grips & electric vest.
Bob N.
'93 FJ
'17 V-Strom DL650
Whitby, ON
FJ-Heizer
I have a Xenon Burner for better Light.The original Light are like a Candle.
flips
Hi there.
Mine are similar to Fjflyer (bike too!)
55w H3 switched on with hi beam.More of a flood than a spot light.
Cheers  :drinks:
Jeff P
Stay rubber side down.
FeralJuggernaut
$20 cheapies from walmart.  +wiring +relay
They are attached at the disabled antidive bolt hole.   I intended to have them add an oddball night time setup to increase my visibility to other drivers.  They are not set to light up the road at speed, but can be helpful at parking lot speed/distance.   I run the relay on signal from the tail light, so effectively, key on.  A couple of picts at http://www.public.asu.edu/~vansanfo/fj/
Safety Fast
Zwartie
Installed these lights a few years ago. $20 at Princess Auto for the set which included the switch and relay.
Close-up of one of the lights installed
Lights turned on
Another view
Here's the switch on the right side of the upper fairing panel
Right now I just have 20W bulbs installed. They seem to give enough light to be noticed and to add a bit of spread to the light produced by the headlight. Thinking about trying LEDs which I believe are available at Home Depot. Much less current draw for the same amount of light.
Zwartie
Ben Zwart
London, ON
1992 FJ1200
1977 KZ200
ELIMINATOR
BMW 1150GS
Moto Guzzi California 3
FJ Flyer
Quote from: movenon on April 15, 2013, 02:34:56 PM
Quote from: FJ Flyer on April 15, 2013, 10:48:36 AM
I like your lights ! What wattage are they ?
Dang, I keep forgetting to check. Hopefully, this afternoon.  Also, here is the bracket I made to mount them.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Cool, I just bought a set from WalMart for 18.95. 55 watt units with fuse, wiring, switch (which is junk) and hardware.
FJ Flyer
Quote from: movenon link=topic=8908.msg83743#msg83743 date=1366054
/quote]
Ok, finally had a chance to dig this up.  They are Hella Optilux 1500 lights with 55w bulbs.  Found them online for cheap.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
I have found a good source of lights to be Cree bicycle headlamps. They are mostly 30 - 40mm in diameter and will fry your eyeballs if you look into them.
Most are up to 1800 lumens with some up to 8000.
ktmaha
What is this headlight relay mod?
1973 Yamaha CT 175
1986 Yamaha FJ 1200
1996 Yamaha TTR 90
1991 Miata @ 8psi
