yzf 600r rear
Started by Fred, September 15, 2009, 02:22:04 PM
Anyone know the width of the collar (spacer) on the disc side of a yzf 600r rear wheel? just realized my wheel didn't come with it. trying to fab something so I can make it to the rally.
I can get the diameter of the piece and of the hole with what I have here, but trying to get width would be at best a guess.
TIA,
It's a p/n 90387-2004C-00,  I paid   $11.86 a few years ago ...
the fan
Quote from: Fred on September 15, 2009, 02:22:04 PM
TIA,
ID 20mm
OD 28mm at seal face,33mm@step.
width total 14mm, 11mm to step
If you can't fab one real quick, Come on down anyway. I will toss the one from my spare wheel in the tank bag. I leave cincinnati tomorrow around noon.
Thanks for the quick reply guys, but in my ham fisted attempt at getting this going I have broken the rear master cylinder mount. So it looks like I'm dead in the water, unless I find the part in the tri-county area, yeah, fat chance.  :ireful:  :dash1:
Fred,
you broke the rally rule.
no major work just before a rally.
threejagsteve
Quote from: Fred on September 16, 2009, 09:53:40 AM
Sorry to hear that, Fred! :(
I couldn't help with the measurements you needed, but I was rootin' for ya!
"If you wanna bark with the big dogs, you can't pee with the puppies!"
Quote from: Mark Olson on September 16, 2009, 12:43:57 PM
Fred,
I know, I didn't plan it that way, it just kind of developed. I wanted to use all of the current tire before I made the switch, then there were delays with the machining. ( can't complain a friend squeezed it for me at his shop for free) I tempted the motorcycle gods and was rebuked :sorry:
jvb_ca
Fred. What did ya break on the rear master mount? One of the bolt holders? Mine also broke when I did my yzf600 rear swap. The brake stay arm was offset too far and caught the master cylinder bolt when the suspension collapsed enough upon the first large bump. Anyways I jammed it back in with only the stub sticking through the bolt hole on the footpeg bracket and the other bolt holding it on. No probs for 5-7k km's. I should be looking for a new master but have not got around to it yet. Also with the monoblocks up front, the rear brake hardly gets used.
Cheers...Jake
Cheers...Jake
86FJ1200
Ontario
I broke the mount on the peg bracket. I tend to use my rear brake, more than I thought actually. I rode around here for a bit with it and was uncomfortable about it. While I could get used to it, the hills of North Carolina would not be the place to do it.
What a downer just b4 a rally. I've done it myself - work on what on the face of it should be a five minute job. Next you know you've gone backwards in time. Lessons learnt I suppose. Andy
Just zip tie the bugger on and go to the rally anyway.
