1984 fj1100 flasher relay
Started by cm08, March 03, 2013, 06:59:24 PM
cm08
Hello all.
Need some electrical help as I have reached the limit of my electrical abilities.
Basically My turn signals are not working.  I traced the problem down to the relay.  When I bang on it it works but it is intermittent.  I figured that the relay is not just the flasher relay as it has way too many wires going to it. Wiring diagram doesn't really make it obvious but I am guessing cutoff and starter relay are integrated in same unit.  Bike starts OK.  Problem is just with turn signals.
Searched forum extensively, no joy.  Is there a way to wire in a separate off the shelf relay for the turn signals? I would be surprised that this has not been done yet.  (By the way what is a reed switch as indicated in wiring diagram)
Many thanks for any help
Reed switch is used as a counter for the self-cancelling indicators.
gonzajr
Quote from: cm08 on March 03, 2013, 06:59:24 PM
Hello all.
Hello is there a way you can send me the diagram. I think the reed switch is a one switch,, like a reed valve on a two stroke engine lets air in  and closes to restrict the air. Or like dials on electrical. Is there a number on the relay that is bad. Also wiggle the wires around the relay may have a bad connection. Do you think this is a transistor type relay. Open it up and with a pocket screw driver. Gonza
gonzajr
Hello all.
this is my full I.D. Gonzajr had a mine laps Thanks
cm08
The wiring diagram I referenced is in this forum's Files section / service manuals / 84-85 wiring diagram.
I did open the relay box.  It is loose connection as the problem is intemittent but it is not with the connector, it is somewhere on the board or hardware (relays).
This is why I want to bypass this relay box but just for the turn signals. (as I stated in my original post)
Thanks
cm08
In case anyone else ever has a flasher relay problem and would also like to add in a cheap off the shelf flasher, I finally figured out how.  Remove the chocolate and chocolate/white wires from the connector to the relay (they are next to each other) and connect them to a new 2 pin flasher relay.
Kgip2k
Excellent tip that works. I now have turn signals...  :good2:
Still working on getting the ol girl back together. Front masters have been swapped, carbs changed, got it running.  Need some air pods, figure out the turn signals, and then worry about the cosmetic situation
Quote from: Kgip2k on June 24, 2018, 09:54:30 AM
Your update post couldn't have come at a better time!
I had my turn signals fail on me the other day on my way home from work..........( rush-hour traffic with no turn signals is sketchy and dangerous! No one here recognizes hand-signals )
After some studying of the OEM wiring diagram and some testing, this is exactly what I did. Mine is a 1990 FJ1200.
Located the failed OEM flasher relay (mine is up inside the left side of the fairing) and pull it out along with the harness connector. Luckily I did not have to remove the fairing, only the left inner panel and the air-scoop.
Disconnect the OEM 5-wire Flasher Relay and discard it.
Substitute a standard Automotive-style 2-wire relay (I used a more expensive "Electronic" flasher that doesn't care how many bulbs you have in the circuit)
Slice-open Thumb on the Oil Cooler when the force on the connector finally exceeds the force required to hold it in place........... :mad:
I used one of my terminal-disconnect tools to slip out the wire and connector for both the Brown "Power" and the Brown/White-stripe "Load" wires from the factory connector.
Installed some Heat-shrink tubing over the bare blade connectors, cause that's how I roll.........
Hook them up to the new 2-wire Flasher blades (flasher doesn't care which way you hook them up)
Zip-tie the new flasher out of the way, and leave the original factory connector somewhere nearby.
Turn Signals now work perfectly again. (Note: This replacement mod will disable the original self-canceling function if it still worked to begin with) Mine did not. That function stopped working some time ago...........
Charlie-brm
Pic of your thumb or it didn't happen.
I'm almost speechless to notice the new relay is "Made in Canada". We still make dinky electronic parts like that and sell them somewhere else?
Nice clear write up. I'm just wondering if a working self cancelling unit can be retained when we're just adapting a new 2 wire part for the actual flashing function.
1979 XS750SF - 2005 to 2012
Quote from: Charlie-brm on July 02, 2018, 02:37:38 PM
Haha. I wasn't going to post the picture of my thumb, but since you asked.......... :sarcastic:
I honestly don't know how you would retain the factory self-cancel function, unless you source a good used original relay.
Sadly my search shows the 1100 relay is no longer available from Yamaha. For the 1988-1990 1200's the flasher is available, but not inexpensive. https://www.partzilla.com/product/yamaha/2UJ-83350-00-00?ref=93b881e6ff215c5125db8e83b6643b9b3fa59961
TexasDave
I suspect that most of the flasher relays are not bad but that the reed switch that sends a signal to them are worn out. The flasher relays count the number of on/off signals sent from the reed switch to determine when to shut off the flasher. The reed switch is activated by a magnet on the tach for every revolution. This means the reed switch is on/off all the time even when not acting as a switch signal for the flasher relay. These reed switches are rated for millions of cycles but that is what they are getting  anytime the bike is running. To check the reed switch it would have to be isolated and a magnet applied and measure continuity between the two wires on the reed switch. If no continuity with magnet applied then the reed switch is bad. No idea where the reed switch is but it would have to be extremely close to the tach. Maybe mounted on side or back of tach.
Dave
Dave,  I thought the self canceling was connected to the odometer, not the tach.
TexasDave
Quote from: Pat Conlon on July 02, 2018, 09:09:51 PM
Pat I think you are correct. I have never seen the switch myself. Has anyone got a picture of the backside of the odometer?
Dave
The reed switch is activated by the speedometer input.
It activates every time the cable completes a revolution. The flasher may have a circuit inside that counts these signals and then turns off the flash once a predetermined number is reached.
In the picture, you can see the reed switch mounted just above the speedometer input.
Down inside the slot, you can see the wheel that turns with the speedometer cable input.
